Water Outlet Pulley leak
Discussion in '2nd Gen 4Runners (1990-1995)' started by rhinolined, Mar 10, 2019.
  1. Mar 10, 2019 at 11:05 PM
    rhinolined
    rhinolined [OP] New Member
    Andrew
    1991 4Runner 3VZ-E 4x4 5-Speed
    Has anyone ever changed out their Water outlet pulley and had it leak on the back where it bolts to the block. I used high temp RTV and tightened all 4 bolts as tight as I could (this motor has had a history of bolts breaking so I didn't want to break them off). Now that the motor is back together I think the tension from the timing belt pulled it forward and caused a leak as every time I start the truck I get coolant/water leaking from that area in a pretty constant stream.
    :annoyed:
    now I have to pull it all back apart and possibly redo the timing belt if I cant fix it without removing the timing belt. :boom:
    I will get better pictures of the leak tomorrow this is the pulley im talking about
  2. Mar 11, 2019 at 7:45 PM
    rhinolined
    Andrew
    So the leak is fixed it was not the pulley but rather a hose i realized i didnt tighten the clamp down and it was leaking :yes:
    now to finalize and finish up this timing issue and she will be purring like a kitten:headbang:
  3. Mar 11, 2019 at 7:53 PM
    aroyalsfan
    aroyalsfan The Owner
    Kansas City
    Couldn't help but notice your cat analogy. Do you like cats?
  4. Mar 11, 2019 at 7:56 PM
    rhinolined
    Andrew
    more of a dog person..... unless said cat is over 100lbs :D
