Water in passenger side
Discussion in '5th Gen 4Runners (2010-2024)' started by akki445, Jul 20, 2024.
  1. Jul 20, 2024 at 10:59 PM
    akki445
    akki445 [OP] New Member
    Akhil
    2020 Trd off road
    Hello
    Took my 4runner ofp out today through some harsh mud and water. But unfortunately I got water in the passenger side. I have no idea how this happened ?
    My guess is that i have holes drilled for body rustproof and the water came through those and through the speaker and went inside.
    Is there any other way this could have happened ? Idk i am confused now. Any help or similar situation is helpful.
    Also any tips to clean it off.
  2. Jul 20, 2024 at 11:05 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Do you have a moonroof? If so, it could be a clogged moonroof drain. However, that seems like a lot of water for such a cause.
  3. Jul 20, 2024 at 11:16 PM
    akki445
    Akhil
    2020 Trd off road
    I think the water came somewhere from under
  4. Jul 21, 2024 at 1:47 AM
    backpacker
    2023 TRD ORP
    The sunroof drain is near the floor.
    kolter45 likes this.
  5. Jul 21, 2024 at 5:47 AM
    Sin4R
    Sin4R New Member
    2024 Underground Limited
    Mall crawling kit.
    In addition to dealing with this issue, I'd also recommend checking/changing fluid in differentials. If water was high enough to get inside cabin, it was high enough to get through breather vents inside diffs.
  6. Jul 21, 2024 at 5:54 AM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    2024 4Runner OR Solar Octane
    I would remove all the seats and pull the carpet so everything has a chance to dry properly, especially anything electronic related.
  7. Jul 21, 2024 at 5:59 AM
    Sin4R
    Sin4R New Member
    Mall crawling kit.
    Sorry to say this, but OP should treat his car as flooded. If you let it sit, mold and musky smell, rust and endless electrical issues will follow.
    5thToy, Han4Run, backpacker and 2 others like this.
  8. Jul 21, 2024 at 7:51 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    @Sin4R and @Tooly are %100 correct. I'd be less worried about where the water came from and more concerned about how I'm going to clean that potential bio-hazard up. Like get seats and carpets out. Stat.
  9. Jul 21, 2024 at 7:49 PM
    I'll never get the fascination with mud holes and water crossings in a vehicle. The cleanup and potential water damage always outweigh any perceived "fun".
    Good luck finding the intrusion spot; and the cleanup.
  10. Jul 21, 2024 at 8:09 PM
    3JOH22A Toyota Gigolo
    The door seals aren't designed for submersion. Water would've also gotten in through the factory drain holes at the bottom of each door and enter through the speaker grille yes.
    • Remove all the seats and center console.
    • Remove the carpet to hose off in your driveway.
    • Remove the foam insulation under the carpet and throw it in the trash - it'll never dry properly and develop mold.
    • Spray some Deoxit in the power seat and airbag connectors.
    • Install some waterproof insulation like Noico or Dynamat.
    • Reinstall carpet. Reinstall seats, center console, and other interior panels.
    • Replace the engine air filter as it's probably soaked in mud.
    • Replace the rear diff oil if you didn't do the breather extension.
    You're lucky water didn't get through the intake and hydrolock your engine, as the intake is on the passenger side. (If you sunk the driver's side, you would've killed the starter within a month.) Other parts like the evap canister, wheel bearings, and steer rack may die within a year. I'm speaking from the experience of half the people in my off-road club. :evil:
    Clogged moonroof drain isn't going to leave muddy water in his rear door cupholders :laugh: You can see the muddy water line on his inner door panel. That's how deep he sunk his 4Runner:
  11. Jul 22, 2024 at 7:07 AM
    UncleShorty
    UncleShorty New Member
    Demolished
  12. Jul 22, 2024 at 8:22 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    And so unnecessary.
    Han4Run and CalcityRenegade like this.
  13. Jul 22, 2024 at 9:21 AM
    java
    java fauxrunner
    2023 ORP ice cap
    Sorry about that. What sliders are you running?
  14. Jul 22, 2024 at 9:35 AM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    For real. At least buy an ATV for this kind of crap.
    kouack likes this.
  15. Jul 22, 2024 at 10:15 AM
    catbrown357
    Tempe
    2011 Limited 4WD
    Those aren't sliders. Those are catchers. They've got steps on them.
    java[QUOTED] and 3JOH22A like this.
  16. Jul 22, 2024 at 10:21 AM
    java
    java fauxrunner
    2023 ORP ice cap
    OP has enough problems to deal with right now, and these comments aren't exactly helpful. We all make mistakes.
    icebear and Spare Parts like this.
  17. Jul 22, 2024 at 12:25 PM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    Did you have fun? Looks like you left it in the mud pit too long. Like you stopped in the middle for a few moments, and shit got in. Don’t stop when in water, drive steady speed till thru.
  18. Jul 22, 2024 at 1:45 PM
    They look like rapist Predator steps, may have even been a port installed accessory.
    Then you would be covered in the smelly mud instead of your vehicle... :crapstorm:
  19. Jul 22, 2024 at 3:10 PM
    akki445
    Akhil
    2020 Trd off road
    So I somewhat managed to clean it out. @3JOH22A I was stuck in water with passenger side down and the water came through the door panels and the speaker. I took out both the door panels sprayed out the mud and debris also cleaned out the speakers. Got it dryed and sprayed some rust proof spray for now.Checked my filter and it was ok water didn't enter there maybe i was lucky enough. Prob need to Check on the differential oil.
    As for the carper for now i have it cleaned with upholsary non foaming cleaner and got rid of all the mud. Looks kinda neat but need to dry it really well. I vaccumed it and used hot air to dry it initially. Haven't taken the carpet out yet but will soon.
    3JOH22A, Slopemaster and java like this.
  20. Jul 22, 2024 at 3:12 PM
    akki445
    Akhil
    2020 Trd off road
    To got stuck in the mud pit. I didn't keep the momentum going through....
    Spare Parts[QUOTED] likes this.
  21. Jul 22, 2024 at 3:21 PM
    Sin4R
    Sin4R New Member
    Mall crawling kit.
    Drying out is for clear water. Mud requires cleaning.
    Looking at the water line, it wasn't just little bit mud getting in, but the car filled couple inches with muddy water. To clean that you will need to take the carpet out (and entire interior) ASAP. Longer you wait, harder it will be to get rid of odors. Once it sets in, you might not be able to sell the car, as anyone getting in will immediately know by smell that it was flooded.
  22. Jul 22, 2024 at 4:37 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Hello
    Really?
    catbrown357 likes this.
  23. Jul 22, 2024 at 5:07 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    Don't wait too long. You're going to be growing mushrooms. Seriously.
  24. Jul 22, 2024 at 5:45 PM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
  25. Jul 22, 2024 at 8:55 PM
    And next month you'll do it all over again :D
    In 2022, one guy in my off-road club ran the trail opposite to the usual direction and forgot to take the shallow side through a water hole. His Tacoma took on water. When he reached camp, 4 experienced people took apart the interior in 10 minutes. We washed the carpet in a lake and hung it on a winch rope to dry overnight. The foam pile underpad was thrown in the bed to be discarded. There was no permanent damage and he continued wheeling and upgrading his truck to this day. All part of the experience.
  26. Jul 24, 2024 at 9:27 PM
  27. Jul 27, 2024 at 9:02 AM
    akki445
    Akhil
    2020 Trd off road
  28. Jul 27, 2024 at 9:48 PM
    That is one awesome group of guys!
  29. Jul 27, 2024 at 10:03 PM
    I prefer to avoid sand and water traps.
