Water damage to heated seat switch
Discussion in '5th Gen 4Runners (2010-2024)' started by Roger82, Apr 7, 2022.
  1. Apr 7, 2022 at 5:49 PM
    Roger82
    Roger82 [OP] New Member
    19 TRD PRO White
    None yet
    Water spilled on/into the switch for the heated seat. Now it turns on while in the off position.
    Will this resolve itself when it drys?
  2. Apr 7, 2022 at 6:10 PM
    Yoytota
    Yoytota New Member
    FL
    SR5 4X4
    I'd pull it and hit it with some CRC electrical cleaner spray and let it dry overnight
    Rocko9999 and Roger82[OP] like this.
  3. Apr 7, 2022 at 6:11 PM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    They are hella easy to remove. Or even the top of the console can be popped off in seconds. Maybe do that, and blow it out with some compressed air. Really, theres nothing to poppin the top off.
    Roger82[OP] likes this.
  4. Feb 19, 2024 at 5:15 PM
    JasminRamsey
    JasminRamsey New Member
    Jasmin
    2013 Black 4Runner
    Spilled water on the heated seat switch can definitely cause some wonky behavior. It might sort itself out once it dries, but there's also a chance it could cause more problems, like short circuits or corrosion.
  5. Feb 20, 2024 at 8:50 AM
    UncleShorty
    UncleShorty New Member
    I spilled coffee in mine. (Fookin' idiots on Harleys need to watch where they're going.)
    The switch failed closed so the heater was always on. Tried to dry it but no dice. I'm in TX so I've never had occasion to use the heater. 5 minutes to lift the console top and disconnect the switch. A new switch was 75 bucks. It bugs me that there's something on "Ol' Hoss" that doesn't work... but not $75 bucks worth...
    3JOH22A likes this.
  6. Feb 20, 2024 at 9:03 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    I would say if it's been a day or longer and it doesn't work, it's prob. shot. You could pull it, put it somewhere warm for a week, then work the switch 20-50 times full on and off. That may wipe away the corrosion enough, worth a try. You can't get inside the switch easily to spray cleaner or contact cleaner like Deoxit. $75 or so new.
