Water Bottle Mounting Locations
Discussion in '5th Gen 4Runners (2010-2024)' started by M-Bear41, Nov 6, 2024 at 11:49 AM.
  1. Nov 6, 2024 at 11:49 AM
    M-Bear41
    M-Bear41 [OP] New Member
    Mojo
    Hi y'all,
    I just got a 1/2 gal Yeti Jug and I would love to find a place to mount it. I'm curious to what y'all have done for inspiration regarding larger water bottles and/or jugs!
    Show me what you've got!
    Thanks,
    Morgan
  2. Nov 6, 2024 at 12:33 PM
    Manhattan
    Manhattan New Member
  3. Nov 6, 2024 at 12:34 PM
    Didn't really realize a 1/2 gallon needed to be mounted.
    Maybe remove the / and 12 gallon and now we talking.
    catbrown357 likes this.
  4. Nov 6, 2024 at 12:35 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    That's huge. Is that part of a shower system or maybe fresh or gray water holding tank?
    I'd imagine you could buy a roof rack. Usually those are rated for 350 pounds max when driving so just a heads up on that. Might need to drill holes to route the plumbing.
    I've seen guys remove the shark fin antena in the back because it was no longer in use due to having an aftermarket stereo, and then use that stock hole to run stuff. Could be a good option.
    Or maybe strap it into your passenger seat. Another option could be..do you want to tow a trailer?
  5. Nov 6, 2024 at 12:36 PM
    M-Bear41
    Mojo
    It’s a thermos I would like to mount for a backup so it’s not rolling around. Helpful comments are appreciated.
    But then yeah I do want a temporary shower or something to wash beach sand off and such
  6. Nov 6, 2024 at 12:45 PM
    Manhattan
    Bit of a paradox in your favor. If you need that much water, the truck's likely packed to some degree for some kinda trip - and the bottle can be tucked somewhere it won't roll around.
    Thacrow likes this.
  7. Nov 6, 2024 at 1:07 PM
    ID_Yeti
    ID_Yeti New Member
    2024 ORP
    32oz Hydroflask fits in the cupholders without the inserts. So you can fit 4 of them for a full gallon.
  8. Nov 6, 2024 at 1:08 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Get 2 32 oz. Nalgene bottles. They fit in the cup holders if you take the inserts out. Done and mounted.
  9. Nov 6, 2024 at 1:27 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Is it for drinking while driving? Seems unwieldy.
  10. Nov 6, 2024 at 1:41 PM
    I would use their mount on a molle panel on the rear side windows or bolt it to your center console so it hangs in the passenger area.
