Vsc problems. Please help!
Discussion in '5th Gen 4Runners (2010-2024)' started by Subadrews, Sep 24, 2024.
  1. Sep 24, 2024 at 6:04 PM
    Subadrews
    Subadrews [OP] New Member
    Collin
    2015 nautical blue 4runner
    Hey everyone, I’m having a huge problem with my vsc/abs. I have a 2015 sr5 and it will randomly act up every month or so by setting off the vsc on dry pavement anywhere from 25-80mph while driving straight. It will also slam on the brakes with absolutely zero warning. It’s extremely dangerous and I don’t want to drive it anymore. I’m scared I’m going to get into an accident I have brought it to 3 Toyota dealerships and no one can figure it out. It doesn’t throw any abs codes. I’ve searched on just about every Toyota and Lexus forum. Any help is appreciated. Please help.
  2. Sep 24, 2024 at 6:26 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Car care nut fellow had a car with a similar problem. Your rack has excessive movement resulting in your ECU thinking you are sliding every time you make a turn and slamming the brakes on it's own. Get your rack checked for wear and tear or excessive play.
    icebear and Kad2112 like this.
  3. Sep 24, 2024 at 6:33 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    That's a good summary of that episode. It's definitely worth checking.
    2Toys likes this.
  4. Sep 24, 2024 at 6:58 PM
    Kad2112
    Kad2112 New Member
    Keith
    23 trd off road premium
    Bilstein 6112 & 5160 with ( B12 1.5 ) springs. 2.5 lift. Dobinson tubular UCA’s. Cooper AT3-XLT 285-70-17. TRD OR Premium wheels
    Don’t throw the parts cannon at it based on my thoughts, but sounds like a wheel speed sensor? ( I am not an expert ). I have watched the video lc200 refers to and it’s worth viewing as well.
  5. Sep 25, 2024 at 9:57 AM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
  6. Sep 26, 2024 at 3:03 PM
    3JOH22A Toyota Gigolo
    Use an OBD2 reader with real time data. Jack the vehicle off the ground with the transmission in neutral. Spin each tire by hand and verify the wheel speed data in the reader shows sensible values with no dropout. If you see abnormal readings, inspect that corner in detail. It's easy to damage the wheel speed sensor wiring off road or doing suspension work. The wheel bearing with the magnetic tone ring may be damaged or has debris blocking parts of it.
    Shredder likes this.
