Vsc and check engine light on help!
Discussion in '4th Gen 4Runners (2003-2009)' started by Leo4, May 31, 2019.
  1. May 31, 2019 at 11:03 PM
    Leo4
    Leo4 [OP] New Member
    So the vsc and check engine light is now on in my 05, Plug in a scanner and it showed that the gas cap was bad, I replace it and still on, now it’s been a few days since I replace the damn thing. I was reading some threats in here and some guy said he had a zpc done ( I have no clue what that is) but I’m not sure if I need to take it to a shop or if I just try to restart the computer by disconnecting the battery. Is this a common issue? Not so serious issue ?
  2. Jun 1, 2019 at 3:43 AM
    Braves95
    Braves95 New Member
    David
    2019 Nightshade Special Edition MGM
    None Yet!!
    Disconnect the battery. Unplug both pos. And neg. Then touch the 2 together. That will sure get all the residual power out and hook back up. See if that clears it.
  3. Jun 1, 2019 at 1:19 PM
    Leo4
    Thanks for the tip, it all clear and have been driving around for a while now and turning off and on truck and it’s seems that it’s all good!, thanks
    Braves95 likes this.
  4. Jun 1, 2019 at 2:08 PM
    Braves95
    Braves95 New Member
    David
    None Yet!!
    Awesome man. Happy trails!!
    Leo4[QUOTED][OP] likes this.
  5. Jun 3, 2019 at 7:20 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    Or you can just pull the ECU fuse and reinstall it.
    Leo4[OP] likes this.
