VSC/ABS lights on dash
Discussion in '4th Gen 4Runners (2003-2009)' started by Eric4194, May 10, 2023.
  1. May 10, 2023 at 1:55 PM
    Eric4194
    Eric4194 [OP] New Member
    Eric
    2007 Sport V6
    OME 3" lift wheels and tires
    I have the dreaded VSC off/ABS lights on and can't figure out why. I changed both front bearing assemplies and all four wheels i did rotors and pads. I broke driver front ABS speed sensor and replaced it with a cheap Amazon one and now I have this. I erased all DTC codes with my OBD II and then i unhooked the battery for 10 min but this did not work. Any suggestions would be appreciated
    TIA
  2. May 10, 2023 at 1:57 PM
    Thepremier141
    Thepremier141 Member
    Nate
    Northern California
    ‘22 SR5P
    The dash in my old 4th gen would light up like this if the gas cap wasn't sealing, I had to get a new one to fix it.
    Libagui likes this.
  3. May 10, 2023 at 4:33 PM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    MI-FL off roader likes this.
  4. May 13, 2023 at 10:22 PM
    360runner
    360runner New Member
    Easton
    2007 Sport / 2023 ORP
    I had a solid mechanic in Washington who knew toyotas like ive never seen before. After the dealership failed to identify this same issue on my vehicle, it turned out to be a driver side rear wheel speed sensor. he pulled one from a junk yard and got rid of a two year eye sore. Hope this helps
  5. May 16, 2023 at 12:38 PM
    sos2715
    sos2715 New Member
    Steve
    2007 Toyota 4Runner Sport Limited 3 in lift, ICON suspension, Nitto 285/70/17
    I had the same issue with my '07 seems the aftermarket LED lights were tripping the ABS lights. I replaced them with another after market LED and it solved the issue.
    I currently have AutoOne H11 6000 Kelvin but I could use something brighter but I will probably stick with the same brand.
