Victory 4x4 Crossbars - does surfboard/paddleboard hit the shark fin antenna?
Discussion in '5th Gen 4Runners (2010-2024)' started by livinthedream, Nov 19, 2020.
  1. Nov 19, 2020 at 11:09 AM
    livinthedream
    livinthedream [OP] New Member
    2015 4runner Trail
    Really love the low profile look of the Victory 4x4 crossbars and how they sit. I mainly will use these to transport surfboards and paddleboards. My question is has anyone had issues with their boards hitting the antenna when they lay the boards flat on the crossbars and strap them down?
    I plan to only use straps to tie down and not have to get another attachment to carry the boards.
    Another option if these are too low profile will be to get the LFD cross bars.
  2. Feb 20, 2021 at 9:52 AM
    Gonna necro this thread. I’m starting to consider my options for crossbars, and will be similarly using it to carry a fairly flat-bottomed fishing kayak. Im worried about the clearance to the shark fin antenna as well.
    Also, interested in general thoughts on these crossbars, victory or LFD, from anyone that owns them.
    caitcards90 likes this.
  3. Feb 20, 2021 at 3:36 PM
    livinthedream
    2015 4runner Trail
    I ended up picking up a stock pair of crossbars for cheap and with my surfboards/paddle boards the antenna digs into the boards so I assume the Victory crossbars would be worse since they sit lower. I plan on getting the pads to put on the crossbars to give more clearance.
    All that to say I think the best option would be to get the LFD crossbars since they sit higher.
  4. Feb 20, 2021 at 4:04 PM
    Mohoman
    Mohoman New Member
    Sean
    99 Limited
    Queen of Battle
    I have 5 LFD crossbars (one fairing). Honest great company with excellent customer service. Only company I've ever had call to give me delay notices.
    Also confirmed it does not hit the sharkfin in the back level at the last crossbar; ~5cm or 1/4 inch clearance
  5. Feb 20, 2021 at 6:48 PM
    Cool, thanks for the replies. Funny how the toyota crossbars arent high enough.... Seems the crossbar dept was not talking to the sharkfin dept. Although they will probably both blame the roof rail dept...lol
    @Mohoman does the crossbar with the fairing end up touching the roof if things flex while moving? Seem to recall pictures of the fairing coming awful close to the roof
  6. Feb 20, 2021 at 7:29 PM
    Mohoman
    Mohoman New Member
    Sean
    99 Limited
    Queen of Battle
    The parcel service in TX shut down for a bit so I actually just received the wind fairing crossbar today. I’ll be installing tomorrow and I’ll try to answer your question. The straight bars are very sturdy and would take well over the Toyota rating for the rails in weight to bend the crossbars. Again, I’ll confirm tomorrow!
  7. Feb 20, 2021 at 9:21 PM
    Thank you, looking forward to your observations. I previously loaded my 80lb kayak on my sienna with factory crossbars. They were strong, but loading a big kayak can be rough at times, which momentarily flexes the factory bars. So im more interested if they would flex under momentary shock loading
  8. Feb 21, 2021 at 10:56 AM
    WIwhale
    WIwhale New Member
    Matt
    2024 jeep wrangler JLU
    I almost got the factory bars and noticed it wouldnt work with the shark fin right away. I mostly use rack for only kayaks or sup boards. I put on the old yakima railgrabs with round bars (its now been used on 3 diff cars) and works very well.
  9. Feb 21, 2021 at 11:08 AM
    If the photo in the original post shows Victory 4x4 cross bars, does anyone have a link to those? All I see on the Victory 4x4 site is this, which looks nothing like the photo above:
    https://www.victory4x4.com/product/XAL.html
    Edit: never mind - after searching through 7 pages of their product list, there they were on page 7. What I don't get is one photo looks like the one above, and another looks like this:
    So, if anyone has these, which is the actual representation of these crossbars?
    bedobe likes this.
  10. Feb 21, 2021 at 12:57 PM
    bedobe
    bedobe Miss Ann Thrope
    Idaho (Soutwestern)
    2020 4Runner OR Premier
    You will probably get an answer from other members before I can provide my own definitive answer, but I ordered a set of three crossbars (V4RRK-CS-5G-PC) on 2/11/21 and am waiting their arrival. I had this same exact question. FWIW: When you purchase the crossbars there is a small picture of the crossbar with the four bolt holes in the outer most positions or edges. The pictured crossbar does not have the 22 slots that show in your posted image. That image also prints out on the invoice although it is extremely small. I'll follow this thread and chime in once they arrive.
  11. Feb 21, 2021 at 6:18 PM
    I appreciate that thanks. I had not seen these prior to today, and am interested due to the lower profile, yet being much sturdier, it seems, than the oem cross bars.
    The LFD crossbars look very strong, but they have a considerably higher profile.
  12. Feb 22, 2021 at 6:24 AM
    victoryrunner
    victoryrunner New Member
    Cam
    2017 SR5 Magnetic Gray Metallic 4Runner
    Falken Wildpeak A/T3 285/70R17 | Mamba Offroad Wheels M23 | 3" BDS Suspension | Victory 4x4 Blitz Front Winch Bumper | Victory 4x4 Strike Sliders
    The photo above is the current hole pattern. It has was updated since the original photos were taken to allow for more mounting options.
  13. Feb 22, 2021 at 6:58 AM
    Thank you, that makes sense - more mounting options is good...would you happen to know what the clearance measurement is between the bottom of the crossbar and the highest point on the roof in the middle?
  14. Feb 22, 2021 at 2:36 PM
    Mohoman
    Mohoman New Member
    Sean
    99 Limited
    Queen of Battle
    Its been a bit hectic here and I opted to wash the 4runner over installing the crossbars. After the snow here in TX, my white 4runner could have almost passed for magnetic grey. I should have it up this week without a doubt.
  15. Feb 22, 2021 at 3:06 PM
    bedobe
    Idaho (Soutwestern)
    PXL_20210222_215432053.jpg PXL_20210222_215113406.jpg PXL_20210222_220011507.jpg
    ATTACH=full]64503[/ATTACH] Received the crossbars purchased from Victory 4X4 (JCROffroad) this afternoon. First and foremost this should answer your question about which exact crossbar version you should get.
    I also had to post images of the bars as received, more specifically how the crossbars were packaged. Unbelievable! Powdercoat shows no flaws. I was also thinking the bars might be on the light weight side. They are not at all. Any heavier and they would be overkill.
    I had a couple question about the crossbars prior to my purchase, and then UPS messed up on the delivery so I had to contact Victory 4X4 regarding that. Every time I reached out to them they personally responded, and not with some automated generic blow-off response. I would not hesitate to purchase from Victory again. In fact I was on the fence when I bought these three bars not knowing what to expect. Now wish I had gone ahead and bought a total of four.
    Hope this helps.
  16. Feb 22, 2021 at 4:25 PM
    @victoryrunner, I got the impression from your post above that the cross bars looked more like this:
    But the crossbars received by @bedobe in the photo below look more like the original photo. Did I misunderstand your post?
  17. Feb 22, 2021 at 4:51 PM
    bedobe
    Idaho (Soutwestern)
    Yes, I too was confused by Victoryrunners reply. After reading that post several times, I was anxious about exactly what I was going to get. What I was wanting, what I thought I'd get, turned out OK since I wanted crossbars configured as you see them in my posted image.
  18. Feb 22, 2021 at 8:51 PM
    I can see your confusion...what I'm wondering is, if I order these, which version will arrive...?
    I'll be looking forward to the installed photos. The photos on Victory's website leave a lot to be desired. You'd think if you wanted to sell something, you'd pay a bit more attention to displaying the product in the best way possible...
    bedobe[QUOTED] likes this.
  19. Feb 23, 2021 at 5:15 AM
    victoryrunner
    Cam
    Sorry for the confusion! The bolt patterns on these were updated a month or two ago. There may have still been some older versions in stock. I will go check in the shipping department and see what will be shipping from here on out. I have not yet had a chance to get installed photos of the updated version, the 4Runners at the shop lately have had full racks.
  20. Feb 23, 2021 at 5:21 AM
    victoryrunner
    Cam
    It looks like they just shipped out the rest of the older design last week. So any order from now on should have the updated bolt pattern.
  21. Feb 23, 2021 at 7:15 AM
    @victoryrunner, thanks for the response. I think what is confusing is, in your responses, you've never definitively stated which photo is the latest version of the crossbar. Then, when @bedobe received his order, and they looked like the original photo, it added to the mystery...can you verify that the latest version of the crossbar will look like the photo above, in this post, so we can put this to rest? Thanks.
  22. Feb 23, 2021 at 7:18 AM
    If I was closer, I'd run over there and give you the opportunity for a photo op...:)
    victoryrunner[QUOTED] likes this.
  23. Feb 23, 2021 at 7:19 AM
    victoryrunner
    Cam
    Yes, this is the latest version.
    SlvrSlug and glwood54 like this.
  24. Feb 23, 2021 at 7:22 AM
    I agree with all the confusion here, in my mind a picture posted by Victory 4x4 would be appropriate, and end all this guessing.
  25. Feb 23, 2021 at 7:23 AM
    :rimshot:thank you!
  26. Feb 23, 2021 at 7:26 AM
    The judges have reached a decision!
    I have to say, these look a lot sturdier and more useful, for actually carrying stuff, than the oem crossbars. In my case, they go perfectly with the black side rails on my truck...
  27. Feb 23, 2021 at 10:40 AM
    Are you using the stock rails?
  28. Feb 23, 2021 at 10:47 AM
    Hmmm. I’m liking the extra height of the LFD cross bars. I live in the rust belt. LFD offer stainless versions. Do you all think it would be a good idea to step up to the stainless? Heck, they even have aluminum! Decisions decisions
  29. Feb 23, 2021 at 8:00 PM
    Johnrg
    Johnrg New Member
    2020 TRD Off Road
    Stock bars with rack pads clear the shark fin. Easy remedy for a little more space is to put a layer of additional foam in the pads.
    F8_wYxqzew195ftCdyDdMGdnGm73WJXrMdnujgdL_4770967f54b4171a9a633491af9bed5d5b7033da.jpg
    SlvrSlug likes this.
  30. Feb 23, 2021 at 11:09 PM
    I currently have the oem black rails & crossbars.
    SlvrSlug[QUOTED] likes this.
