Vibration in Steering wheel
Discussion in '5th Gen 4Runners (2010-2024)' started by Cush7775, Sep 3, 2023.
  1. Sep 3, 2023 at 6:24 PM
    Cush7775
    Cush7775 [OP] New Member
    Chicago Illinois
    2016 Toyota 4runner
    None
    Had 80k mile service done at dealership. New front back brakes as well. They rotated tires and now any speed past 45-50 mph the steering wheel shakes then mellows out but Because 90%of my driving is 50mph or less to work I've dealt with it. Is it normal for AT tires to cause this after rotation?
  2. Sep 3, 2023 at 8:06 PM
    Startrek
    Startrek New Member
    On my first 4runner it started to shake after first 5k tire rotation and never went away. Sold it with third set of rotors. New 4runner will never see dealership. To much troubles for free service.
    Toy4X4 likes this.
  3. Sep 3, 2023 at 9:40 PM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    Check your air pressure, and then also make sure your tires are balanced - that’d be where I’d start.
  4. Sep 3, 2023 at 9:49 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey @Cush7775 yeah check that your tire pressure isn't a little low. I mean it could be in need of a further balance, even a road force balance. Also, depending if/how often you've rotated them, could just be the previous tread wear sits in a sightly different position now?
    Toy4X4 likes this.
  5. Sep 3, 2023 at 10:04 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    If there was uneven wear on tires and they were rotated, they could cause steering vibration.
    Check thread depth, bald spots, air pressure and get them balanced.
    Toy4X4 likes this.
  6. Sep 4, 2023 at 12:46 AM
    pastoreater
    pastoreater New Member
    2023 sr5 2wd toyo 115T
    Not normal. Possibly you had the vibration on a rear wheel and it wasn't noticeable until it rotated to the front
    Toy4X4 likes this.
  7. Sep 4, 2023 at 4:13 AM
    Had a slight shake of steering after rotation, went to get tires rebalanced and found that the initial wheel weight position was not even close! Could be due to wear, improper alignment, etc. Some AT tires also seem to be very air pressure sensitive.
    Sleestaks and bassist like this.
  8. Sep 4, 2023 at 1:28 PM
    Gumpus
    Gumpus New Member
    I used to have responsibility for steering wheel vibration (among other things) at a major manufacturer. It is not normal for AT tires to create a new vibration after rotation. I expect that your issue is radial force variation in one or both of the tires that are now on the front. All tires are imperfect and the stiffness of the tire varies as it rotates. Some tires are more uniform than others. There's a spec for radial force variation. It's not imbalance. If one or both of your front tires are near the high limit of the spec then you get vibration. I expect that the 4Runner is somewhat sensitive to tire non-uniformity given the huge number of posts on this topic. Your solution is to go to a competent tire shop that has a Hunter Road Force balance machine and ask for a road force balance and ask for the road force numbers on all four of your tires since they measure it. They may be able to improve it by doing a "road force balance" which is simply lining up the stiffest point on the tire with the lowest point on the wheel to trick the tire/wheel assembly into acting a bit more round. But if you see road force numbers in the 15 pound range (or more) you're probably screwed unless you buy new tires or ask them to put the tires with the lowest road force numbers back on the front.
  9. Sep 5, 2023 at 6:55 AM
    RNR4P
    RNR4P What to do next.....
    PennyG
    Fort Worth, TX
    2016 Attitude Black Limited Love
    She shall be Wednesday
    So I have had wheels rotated and balanced. Twice. I had new rotors and pads installed front and back. STILL have a vibration in steering wheel at higher speeds (55-70 ish) and more noticeably in sweeping curves. WHAT COULD IT BE? My son suggested a tire out of round but wouldn’t that have been found when balancing? Then maybe wheel bearings? Could it be an alignment issue ? It doesn’t pull that I can tell on the flats or while braking.
    Again this is my forever vehicle. I want stuffdone right. I don’t know what to check next.
    Thank you for this info.
    I do laugh when I see Pathfinder. Don’t know why. I’m a child I guess.
  10. Sep 5, 2023 at 7:04 AM
    RNR4P
    PennyG
    Fort Worth, TX
    I guess my big question is~~ is it hurting anything??
    I’m loading up to drive to east coast, about 1300 miles, with a dog and cargo on roof rack and inside that includes 10 boxes of flooring. Not the lightest load.
    To me it seems anything that bounces like that has to be wearing something out.
  11. Sep 5, 2023 at 7:30 AM
    @RNR4P sorry to hear that, I have a '16 Trail, luckily not much vibration ever only a bit when my Load E's are running lower PSI range.
    Start your own thread.
    Goodluck !
  12. Sep 5, 2023 at 7:44 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    The weights of the tire rims did the vibrations .. the weights are falling off adhesion ..
  13. Sep 5, 2023 at 8:11 AM
    Charlievee
    Charlievee New Member
    Same boat after i got back from deployment. Had a shop road force, rotate them... Still have the issue. Right at 60 mph. I am checking for other shops as i don't trust the one i went to (5 star reviews, lol).
    pastoreater likes this.
  14. Sep 5, 2023 at 8:28 AM
    @Charlievee damn sorry to hear that, honestly it's prolly not the shop; this is a notorious 4R issue that goes deeper that balancing. If you Search on this website, there's a plethora of threads that will help you drill down.
    Goodluck!
  15. Sep 5, 2023 at 11:11 AM
    Charlievee
    Meh, i had the issue new off the lot back in 2018. Got them balanced and it went away, then new tires, another set of tires and it hasn't been an issue. Significant other uses the truck while i deployed and the issue is back. Won't be going back to the last shop because they beat the hell out of the rims. One of benefits of moving every three to four years, you always have to find new credible shops. noticing the ball joints in the JBA'S are a bit subject also, keep wanting more grease.
  16. Sep 5, 2023 at 11:16 AM
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    Just rotated my tires at 35K service last week and now getting the shimmy too.
    Will get them rebalanced and see what happens. First 35K was flawless so I know it's the tires.
    Jason
  17. Sep 5, 2023 at 11:22 AM
    Good to know sure, I repeat, you'll find answers in the Search feature
  18. Sep 5, 2023 at 5:42 PM
    RNR4P
    PennyG
    Fort Worth, TX
    Unfortunately, you can’t figure out one specific thing that it is. I don’t mind having them road force balanced. I don’t mind having an alignment done. But it gets pricey, if none of those work. And right now I’m not in the market to put all new tires on it just to see if it does away with that shimmy.
    It shimmy’s in the steering wheel between 60 and 70-75-ish. It’s shimmys from the floor 75 to 90. At 90 It runs pretty smooth. Unfortunately, the speed limit between here and Virginia is roughly 70 mph.
  19. Sep 5, 2023 at 5:50 PM
    No ya you're absolutely right. Dude, I've read so much on this subject and seen guys burn so much money which obviously is a concern of yours. Use the search feature first before booking multiple road force balances and such. I mean Jesus ya done rotors, pads front AND back. Rotated, balanced, twice. As Kevin O'Learly says, stop the madness (for a minute)
    RNR4P likes this.
  20. Sep 5, 2023 at 7:04 PM
    j cat
    j cat New Member
    massachusetts
    THE TIRE PATHFINDER IS A CHINA MESS .. DID THE TIRE DAMAGED
  21. Sep 5, 2023 at 8:20 PM
    TeslasBigCarbonFootprint
    Southern California
    '23 TRD ORP Super Ice Cap White
    There is a known problem in recent years. That said, Japanese or American-made tires are better.
    j cat and RNR4P like this.
  22. Sep 6, 2023 at 3:43 AM
    RNR4P
    PennyG
    Fort Worth, TX
    All good info. Pathfinder is what it came with and I’ll wear them out. I leave tonight for a 1400 mile trip. It’s loaded down pretty good so we shall see. It’ll end up being about 3-4k r/t.
    When I’m ready for new tires I’ll be looking here to find a gazillion opinions but I do like the sound of American made. Japanese I’d have to research.
  23. Sep 6, 2023 at 11:45 AM
    Charlievee
    I am well read on the subject, but just to be sure, your suggestion is to swap to a Dana carrier or ARB? Lol.
  24. Sep 8, 2023 at 12:53 PM
    j cat
    j cat New Member
    massachusetts
    well the South Korea tires a company did the china tires ...pathfinder ,,, wearing it and the tires wrong .
  25. Sep 8, 2023 at 1:00 PM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    I would check the lug nuts first. Then bring it back.
  26. Sep 8, 2023 at 1:07 PM
    j cat
    j cat New Member
    massachusetts
    the lug nuts are 85ft lbs. psi torque ...your runner
    I was my rotating tires then do the 85ft lbs. then the 4runner is one day ago , then the torque wrench 85 torque .very good spec..
    Ripper238[QUOTED] likes this.
  27. Sep 8, 2023 at 7:30 PM
    RNR4P
    PennyG
    Fort Worth, TX
    Ok seriously lug nuts torqued incorrectly could be the problem? I think I brought my torque wrench with me
  28. Sep 8, 2023 at 7:46 PM
    PIPYotaride
    PIPYotaride Kevin
    Birmingham, Al
    2023 Lunar Rock ORP
    3x2 lift On 33’s KDMAXX PRO TUNE 10.0
    Are those wheels hub centric or lug centric? Are they multi pattern wheels or 6x139mm strictly?
  29. Sep 8, 2023 at 7:48 PM
    Southern California
    Not 76ft lbs?
    Charlievee likes this.
  30. Sep 9, 2023 at 7:03 AM
    Ripper238
    2019 TRD OR
    Yes. Though unlikely it would be my first thing to check that's easy.
    One time I had a strange shake/wobble feel (On my Van) after a break job so I immediately pulled over and luckily I did because the wheel was starting to weir on the treads. Tightened them right on the spot.
