Vibrating feeling between 30 and 40 MPH
Discussion in '5th Gen 4Runners (2010-2024)' started by Jonny4x4, Feb 3, 2023.
  1. Feb 3, 2023 at 12:07 PM
    Jonny4x4
    Jonny4x4 [OP] New Member
    Jonny
    TN
    2013 Toyota 4Runner SR5
    I've noticed a vibrating feeling when I am driving between 30 and 40 MPH. If I accelerate quickly it does not happen. If I let off the gas it stops. I just had the tires balanced, transmission fluid changed, and diff fluid changed. New brakes/rotors as well. Any thoughts? This is on a 2013 4Runner SR5.
  2. Feb 3, 2023 at 12:53 PM
    Foothills
    Foothills New Member
    Where do you feel the vibration, steering wheel or in the seat or both ? How old and what type of tires ? Does the vibration happen in 2WD or in 4WD or both ? When were the prop shafts last greased ? How many miles and what model of T4R, lifted or stock ?
  3. Feb 3, 2023 at 1:31 PM
    Jonny4x4
    Jonny
    TN
    Mostly in the steering wheel. Tires are about a year and a half old. Tires are bf goodrich all terrain ko2. I only notice in 2WD but have not placed it in 4WD much lately. Not sure when the prop shafts were last greased. 180,000 miles on SR5, stock.
  4. Feb 3, 2023 at 1:50 PM
    Foothills
    Steering wheel vibration is often front tires, try rotating front tires to the back. Front and rear prop shafts and u-joints should be greased at least once a year, about every 15k miles unless driving through streams and such frequently, there's a couple of youtube sites on how to grease 4R shafts correctly, not too much grease etc.
  5. Feb 3, 2023 at 3:01 PM
    Jonny4x4
    Jonny
    TN
    I will try that out. Much appreciated!
  6. Feb 3, 2023 at 6:20 PM
    Brownspotz
    Brownspotz High Class Hyena
    2022 sr5 4runner
    Upper control arms , ECGS bushing
    Possibly that bushing in the front differential. My 2022 had a light vibration and growling noise at 30-40 mph. Replaced bushing, problem solved. I didn't feel like playing games with the dealer so I did it myself
  7. Feb 3, 2023 at 8:38 PM
    Jonny4x4
    Jonny
    TN
    Do you think this could be a transmission issue?
  8. Feb 4, 2023 at 6:23 AM
    Have you tried shifting into 4HI yet to see if the vibration goes away? Doing so is the easiest way to confirm or eliminate one possibility.
  9. Feb 4, 2023 at 8:29 AM
    Jonny4x4
    Jonny
    TN
    I have not but will try that out. Thanks.
  10. Feb 4, 2023 at 10:56 PM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Its your tires.
  11. Feb 7, 2023 at 6:04 AM
    Jonny4x4
    Jonny
    TN
    I tried shifting into 4HI and still did the same thing. I have noticed that when I place it manual shift it does not happen. Any thoughts on that?
  12. Nov 10, 2023 at 11:43 PM
    nizzybeats4runnin
    nizzybeats4runnin New Member
    Nizzy
    Did you end up figuring out what the issue was? My 4Runner is doing the same exact thing.
  13. Nov 11, 2023 at 8:30 AM
    Steve Berman
    Steve Berman New Member
    What if you feel it in the seat? Curious
  14. Nov 11, 2023 at 8:32 AM
    Steve Berman
    That's odd. Does it worsen under load at lower RPM? And improve when you wind it out to a higher RPM?
  15. Nov 11, 2023 at 8:36 AM
    Wren
    Wren New Member
    Check torque on your lower control arm cam bolts. That solved the problem for me.
  16. Nov 11, 2023 at 9:44 AM
    Saker New Member
    21 Black T4RORP
    How often (miles) do you balance and rotate your tires?
  17. Nov 11, 2023 at 10:01 AM
    Fortuner
    Fortuner New Member
    CA
    2021 4Runner TRD Off Road Premium w/KDSS
    It’s those BFG’s. I had 3 sets, all did the same. After balancing they would be great for a week or so, then shakes again. Most techs don’t use the balance machines correctly either. Switched to Toyos, no issues.
    If new tires aren’t an option, @nimby posted a write up on how to get a proper balance…it’s worth a read.
    nimby likes this.
  18. Nov 11, 2023 at 11:07 AM
    Saker New Member
    21 Black T4RORP
    They are problematic sometimes, but it’s not all bfg ko2’s. I have some on my T4R with 46k and have no issues. Road force balanced and checked/ rotated every 5k.
  19. Nov 11, 2023 at 11:30 AM
    Fortuner
    Fortuner New Member
    CA
    I didn’t say all, but more often than not we find posts on both forums of people with KO2’s that won’t properly balance. That being said, I acknowledge that other brands may have this issue, and some people experience the vibrations with their factory provided tires…
    However, in my experience, employees at the tire shops I’ve worked with claim that KO2’s & Falken’s are more prone to balancing complaints. They often take more weight & effort to balance out, and inexperienced tech’s trying to pump out installs will frequently use a “smart weight” approach that isn’t reliable.
    I don’t have technical data on this; my feedback’s limited to personal experience & discussions with technicians, mechanics, and consumers in the past few years of modifying my 4R.
    Saker[QUOTED] and Steve Berman like this.
  20. Nov 11, 2023 at 4:32 PM
    Saker New Member
    21 Black T4RORP
    I definitely acknowledge that you didn’t say “all”. I just clarified because some may take it as such. Also, I definitely agree with the remainder of your posting!
    We are on the same page.
    I guess, I got some good ones and also, my tech is very good at keeping them in balance.
