Vehicle not starting.
Discussion in '3rd Gen 4Runners (1996-2002)' started by ThatGuyD, Jun 19, 2023.
  1. Jun 19, 2023 at 4:11 PM
    ThatGuyD
    ThatGuyD [OP] New Member
    David
    1999 4Runner Limited
    Hey guys, new member here! So a few months back my 4Runner suddenly started lurching while I was driving and then ended up turning off. Got it towed home and go it to start a few times after but not for long. Now it won’t start at all. She’s getting fuel but you could smell unburnt fuel on the old plugs. Replaced coil packs, plugs, wires. Still won’t start. Battery is good, alternator tested good as well. Not sure where else I should look now, hoping someone has some info to help me out.
  2. Jun 19, 2023 at 5:27 PM
    Well, it won’t run if there is a leak in the intake duct from the air-cleaner start there.
  3. Jun 19, 2023 at 6:01 PM
    ThatGuyD
    David
    No leak, did a smoke test as well when I first got it home. Forgot to add that in the post, my apologies
  4. Jun 19, 2023 at 8:08 PM
    CEL? Codes?
  5. Jun 19, 2023 at 8:10 PM
    Ahdofu
    Ahdofu New Member
    Matt
    You've replaced the ignition wires, .., etc. Have you confirmed that you get sparks? Any codes from the OBD?
  6. Jun 19, 2023 at 10:46 PM
    ThatGuyD
    David
    Confirmed getting spark, no codes on 3 different readers
  7. Jun 20, 2023 at 7:30 AM
    That's weird. If you have spark, I believe the ECU has all the inputs it needs and is trying to start the car.
    I'm thinking you need to check spark on all plugs.
  8. Jun 20, 2023 at 8:34 AM
    ThatGuyD
    David
    I have check all plugs lol
  9. Jun 20, 2023 at 9:09 AM
    For spark? Seems like plugs that you say are wet with fuel are not be getting spark.
  10. Jun 20, 2023 at 9:26 AM
    ThatGuyD
    David
    Those were the original plugs that I pulled. I used a spark tester before replacing my coil packs, one was slower than the other two and after I replaced them now they’re all on par
  11. Jun 20, 2023 at 6:09 PM
    Ahdofu
    Ahdofu New Member
    Matt
    If you're getting both fuel and spark and there are no codes, I am then baffled as to why engine does not even start. This may sound stupid but I'll ask anyway. Are the plug wire connections correct?
  12. Jun 20, 2023 at 7:04 PM
    steelevo
    Utah
    Air, fuel, and spark are the easy things to check. Then you have the crank and cam sensors. Also, double check that timing belt hasn’t lost teeth, stretched, or jumped timing. If all of that checks out, then it’s off to check valves, ecu, injectors, etc.
  13. Jun 20, 2023 at 7:11 PM
    ThatGuyD
    David
    Cam sensor good, checked that this morning. Crank sensor is stuck so I’m gonna pull the front clip to check the timing and shit so I’ll check that then as well.
  14. Jun 20, 2023 at 7:11 PM
    ThatGuyD
    David
    Yeah haha I double checked that this morning too
  15. Jun 21, 2023 at 2:06 AM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    Compression test, no compression, no run.
  16. Jun 21, 2023 at 5:45 AM
    ThatGuyD
    David
    Compression is good, have a note somewhere with the numbers but everything at least hit the minimum
