Vanity mirror light bulb replacement
Discussion in '5th Gen 4Runners (2010-2024)' started by T4R2018, May 30, 2021.
  1. May 30, 2021 at 7:23 PM
    T4R2018
    T4R2018 [OP] New Member
    Don
    2018 4Runner TRD Off Road
    Has anyone ever while replacing vanity mirror light bulb have the bulb fall on top of the headliner? I would like to get it out.
  2. May 30, 2021 at 9:42 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Inspection mirror and a flashlight to see if you can locate its resting place(if the hole it used to disappear is large enough). Then, if you locate it? put some sort of a very sticky substance on the end of whatever tool you think will reach it. Whether that be a a screwdriver or a flexible tool, (like a claw retrieval tool or whatever). If you can't locate it, then the only way you likely will is to drop however much headliner is necessary. At that point you'd be better served to forget it. imo
  3. May 31, 2021 at 5:11 AM
    T4R2018
    Don
    Thanks You! I’m thinking forget it is the way to go right now. Maybe it will work its way to the front where the headliner meets the windshield. I can pull down on the headliner and it will drop out.
