Valve cover gasket and plug seals brands
Discussion in '3rd Gen 4Runners (1996-2002)' started by 4runnerDawg, Aug 24, 2024.
  1. Aug 24, 2024 at 12:34 PM
    4runnerDawg
    4runnerDawg [OP] New Member
    1998 2WD 4cyl 4runner
    rustoleum paint
    What brand of spark plug seals is proven to seal well for a 3rzfe?
    on Rockauto i see victor reinz, mahle, and beck arnley? i had some duralast and they seem to not be sealing.valve cover is fine but need to fix the plug seals and will do valve cover with them.
  2. Aug 24, 2024 at 1:13 PM
    that'smy4runner
    that'smy4runner New Member
    Toyota, Toyota and Toyota.
  3. Aug 24, 2024 at 1:52 PM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    If I had to get aftermarket gaskets I'd go with Felpro. If you want to save money, this is the sort of part to try with.
    Though keep in mind if it doesn't work, you waste not only the time it takes to replace the part, but the time it took to install that part in the first place. This is why almost everyone recommends buying OEM on seemingly basic things that shouldn't be hard to imitate aftermarket.
    4runnerDawg[OP] likes this.
  4. Aug 24, 2024 at 4:27 PM
    Dreadloc74
    Dreadloc74 New Member
    1997 green 3rd gen 4Runner
    3 in bilstine lift
    Felpro or mahle. The dealer puts there name on other brands (being a Toyota tech) they use NGK plugs and most of the time mahle gaskets. This motor has a bad reputation of leaking anyway but those gaskets will do the job. duralast never lasts. Pretty sure it’s just to get home from the side of the road. I wouldn’t use that brand for anything but emergencies in my opinion.
    good luck!
    PhantomTweak and 4runnerDawg[OP] like this.
  5. Aug 25, 2024 at 2:37 PM
    that'smy4runner
    Makes no sense to use anything but OEM unless you don't mind doing it twice.
    negusm likes this.
  6. Aug 31, 2024 at 3:19 PM
    fox744
    fox744 New Member
    When installing valve cover seal make sure both seal track and seal are clean and free of any oil otherwise it will leak
  7. Aug 31, 2024 at 7:42 PM
    BLKNBLU
    BLKNBLU New Member
    2019 TRD OR Nauti Blue
    I know it's a week later but I have all that stuff OEM for sale in the 3rd gen marketplace if you haven't already purchased.
