Valve chatter
Discussion in '4th Gen 4Runners (2003-2009)' started by red-brian87, Apr 5, 2023.
  1. Apr 5, 2023 at 5:35 PM
    red-brian87
    red-brian87 [OP] New Member
    Brian
    Roanoke va
    2004 4runner limited v8
    I'm experiencing what I believe is valve chatter is this normal? I just hit 260,000 miles I have the 4.7 v8. The oil is changed every 5000 miles if that helps
  2. Apr 5, 2023 at 5:38 PM
    No, I don't believe Valve chatter is normal on those engines. Mine sounded like a brand new Cadillac at 257k. But, what you might be hearing is an exhaust leak at the manifold. The exhaust manifolds are notorious for cracking on the 4.7.
    CygnusX-4 likes this.
  3. Apr 5, 2023 at 5:40 PM
    red-brian87
    Brian
    Roanoke va
    Ah ok. I plan on putting headers on it when ever I get some extra cash flow and true duals. I have a catalytic converter code I'll get fixed then as well thanks!
  4. Apr 5, 2023 at 5:46 PM
    Are you planning on putting on a kit? Or, custom exhaust? It seems like an x- pipe is recommended with true duals.
    With that many miles, it might be worth putting on a new cat. I believe magnaflow makes high flow cats that are reasonably priced. I haven't actually seen it personally, but I have heard that cats tend to clog up after a lot of miles.
  5. Apr 5, 2023 at 5:48 PM
    red-brian87
    Brian
    Roanoke va
    I would do a custom exhaust for it with the x. Also I'm sure they do just like any filter they eventually plug up I would guess.
  6. Apr 5, 2023 at 5:50 PM
    It certainly makes sense. That 4.7 is a glorious motor! I will not even pretend that I don't miss it. :D. And, the 1gr really isn't bad. It just doesn't have that amazing torque.
  7. Apr 5, 2023 at 5:52 PM
    red-brian87
    Brian
    Roanoke va
    It is still a 19 year old suv with issues but I can't bring my self to let it go so I keep fixing stuff lol
  8. Apr 5, 2023 at 6:02 PM
    Unless the frame is rusting through, it's probably worth fixing. I kind of think the 4th gen is underrated. I love my 2019, but my '03 was the best vehicle I've ever owned. The current one still has time to prove otherwise, but It's going to take a while to change my mind.
  9. Apr 5, 2023 at 6:04 PM
    red-brian87
    Brian
    Roanoke va
    Yes the frame is rusting but had it half asked fixed to pass inspection
