Using stock tire size, best way to do a minor lift/level on 4runner with KDSS?
Discussion in '5th Gen 4Runners (2010-2024)' started by RuggedJay, May 23, 2023.
  1. May 23, 2023 at 9:45 AM
    RuggedJay
    RuggedJay [OP] New Member
    I have a KDSS 4runner with stock suspension and want a minor lift and more leveling using stock tires. I do not want to compromise MPGs or on road comfort for bigger tires. What's my best option for a minor lift to the rear (maybe .75") and level the front(approx 1.5"). I'd like a slight rake so that if I put gear in the back (approximately 250-300pounds) it will still be level.
  2. May 23, 2023 at 10:04 AM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    i’d take a look at the eibach stage 1 pro lift with their 1” spring for the rear.
    bilstein 5100s are another option but are generally considered a more firm shock.
    Thatbassguy and RuggedJay[OP] like this.
  3. May 23, 2023 at 12:42 PM
    @nimby used the Eibach Sport Truck shocks to raise the front 1.6", did not raise the rear, and he seems happy with the results. I imagine you could use the same setup with a 3/4" spacer in the rear to maintain a bit more rake. The Eibach shocks are far superior to oem.
    I used the same shocks to raise the front of mine .85, and put new shocks in the rear with no lift.
  4. May 23, 2023 at 1:57 PM
    RuggedJay
    Is that stock tire size? What type of shocks did you use on the rear?
  5. May 23, 2023 at 2:01 PM
    Stock size tires - 265/70-17 Falken Wildpeak SL load. Same Eibach Sport Truck shocks on rear with no ride height change.
  6. May 23, 2023 at 2:14 PM
    RuggedJay
    Are you using factory coils?
  7. May 23, 2023 at 7:05 PM
    Do what @glwood54 did.
    Sounds perfect for you.
    RuggedJay[OP] likes this.
  8. May 24, 2023 at 6:33 AM
    Yes.
    RuggedJay[QUOTED][OP] likes this.
