Used wrong fluid for power steering
Discussion in '5th Gen 4Runners (2010-2024)' started by vietpimp, Nov 12, 2024 at 11:22 AM.
  1. Nov 12, 2024 at 11:22 AM
    vietpimp
    vietpimp [OP] New Member
    Friday
    Hi everyone, I took my 4runner (2016) to a shop to have them check the power steering as the fluid was below min level in the reservoir and I was afraid that there might have been a leak somewhere. After checking everything, the mechanic said there was no leak and the pump was still working fine. He topped up the fluid but instead of using ATF like the manual says, he used normal PSF. Would that cause any issues? Should I have them flush the system and refill with the correct fluid?
  2. Nov 12, 2024 at 11:25 AM
    Don't lose any sleep.
    Rocko9999, Toy4X4 and RUNNER4DAN like this.
  3. Nov 12, 2024 at 1:20 PM
    jeepster09
    jeepster09 "Old"-Member....
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
    Nothing to worry about. All vehicles used to use ATF. I have used both without issue.
    Toy4X4 likes this.
  4. Nov 12, 2024 at 1:52 PM
    Pavo
    Pavo New Member
  5. Nov 12, 2024 at 4:11 PM
    icebear Recovered Kia Owner
    I wouldn’t worry too much since it’s there just for fluid pressure and lubricating simple bits, if you are still concerned since it’s not “proper” and don’t want to deal with flushing then you could do a handful of drain/fills via the reservoir over time. That’s what I’ve been doing to refresh the fluid in my steering system.
    Pulling hoses would be overall quicker and do it all at once but going from the reservoir lets me squeeze it in wherever without much prep.
  6. Nov 12, 2024 at 7:40 PM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    It's fine. Plenty of people have switched between these fluids with no issues
    jeepster09 likes this.
  7. Nov 13, 2024 at 10:31 AM
    MAXIM
    MAXIM New Member
    Both ATF and Formulated Power Steering fluids are Hydraulic Fluids. You are okay no matter what you use.
