Upper Control Arms??
Discussion in 'Suspension' started by sam95, Jan 16, 2024.
  1. Jan 16, 2024 at 2:31 PM
    sam95
    sam95 [OP] New Member
    Samuel
    2014 4Runner Sr5 premium 4x4
    I recently got a 2014 sr5 premium 4runner and am planning on lifting it. I made another post about what lift kit I should purchase and I think I am going to buy this Bilstein B8 6112/5160 3 inch lift kit from Mudify. The kit gives me the option to purchase upper control arms with it. The options they give are:
    Old Man Emu ($606)
    SPC Adjustable ($695.95)
    Camburg Uniball ($749.99)
    Tuff Country Uniball ($408.95)
    I don't know if these are the best options, but I want to know if anyone has experience or thoughts on these. Or if anyone knows of any better choices that I could just buy separately. I would really appreciate your thoughts.
  2. Jan 16, 2024 at 2:42 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I went with SPC. Holding up good so far. Tinkerer's Adventure has done a couple videos on UCA's if you're curious.
    When my SPC's go out I'll likely upgrade to something a little more beefy.
    The SPC allows A LOT of adjustment. If you're going over 2.5-3" in the front, you may need that caster adjustment. This is why I went with SPC originally.
    I wanted 4 degrees of caster and a 3" lift.
    Edit from the future: Avoid SPC like the plague. Ball joints failed in less than a year and they would not warranty them. Go with Dobinsons tubular for the same price. If you really need the extra adjustment get Dobinsons billet.
    djwantke and sam95[OP] like this.
  3. Jan 16, 2024 at 2:45 PM
    hvac guy
    hvac guy New Member
    I have the Old Man Emu UCA's, had them for over a year, with a 2 1/2" lift and haven't had any issues with them. I would definitely recommend them, as for the other choices I have no experience with them
  4. Jan 16, 2024 at 2:56 PM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2023 4Runner TRD Off Road Premium
    ADD W1 Oil Catch Can. ARK Splash Guards. Baxter Performance TK-501-BK Oil Filter Adapter. Canvasback Back Hatch. Differential Breather Relocation. Diode Dynamics SS3 SAE Yellow Pro Fog Lights. Dongar Industries Adapter. DRL Mod Harness. Garmin Mini 2 Dashcam. Lab Ops Gear Dash Mount. Overland Torque Tune. RokBlokz Mud Flaps. SAIS FIlter Mod. Stahlbus Oil Drain Plug. Yokohama Geolandar A/T4 G018 LT265/70R-17. Yota Xpedetion Pro Grille. Yota Xpedetion Valances.
  5. Jan 16, 2024 at 3:14 PM
    3" of lift is a little high, it will leave you with very little downtravel and isn't necessary to fit bigger tires. 2 inches of lift is actually the ideal on these.
    JBA arms are really highly regarded, there's been a few videos and mentions of people having issues with the SPC arms, so be careful.
    Unless you're going for a max articulation long travel setup, I wouldn't go with anything with any type of uniball, because it's going to require a ton of maintenance. You want a conventional, greasable style ball joint.
    sam95[OP] and 1SilverRunner like this.
  6. Jan 16, 2024 at 3:23 PM
    In the past I used SPC. Since I go to dealership for oil changes it was little inconvenient to stop by at my local 4x4 shop to re-grease the UCAs.
    For my new 4R when I list I'm trying to see if I can lift to max where I can keep the maintenance free factory UCA. I don't want un-even tire wear either. Not sure. Just a little thought.
  7. Jan 16, 2024 at 3:35 PM
    3" is fine anything more causes issues.
    I had Icon UCA's and I'd recommend against them. Unless you like bushing squealing like a dying pig.
  8. Jan 16, 2024 at 4:30 PM
    TrailSpecial22 New Member
    PA
    my vote is for Camburg then OME
    sam95[QUOTED][OP] likes this.
  9. Jan 16, 2024 at 6:34 PM
    sam95
    Samuel
    Thanks for yalls ideas, I have looked at the JBAs that a few people mentioned and they look good and the price is pretty appealing. But I will look into the OME ones a little more as well.
  10. Jan 16, 2024 at 7:15 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I 2nd that.
    If you can handle greasing them every oil change. Go with jba. Had mine for 2 years, and love them. Id had a couple different shock/lift set ups. And was always able to achieve a great alignment.
    Toy4X4 and sam95[OP] like this.
  11. Jan 17, 2024 at 3:37 AM
    Stay away from any uniball UCA's unless you monitor their condition frequently, they are not as maintenance free as others. JBA offers 'greasable' UCA's as do some others. Greasing things is no big deal. It also gives you the opportunity to look over parts of the 4Runner.
    hvac guy and sam95[QUOTED][OP] like this.
  12. Jan 17, 2024 at 4:28 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Very pleased with my Old Man Emu arms. Grease ball joint every other oil change and no noise. Got mine for $100 less at Wheelers when they had a big sale.
  13. Jan 17, 2024 at 12:33 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    This ^
    Did you achieve a full 4⁰ castor?
    My last alignment got my SPC's to 3.4⁰ driver side, 3.7⁰ passenger. I believe I heard passenger often gets higher castor applied to offset road angle.
    Yesterday I just swapped my grease zerk SPC balljoints (2.5 yrs old) for new and improved sealed joints. Huge difference, very happy.
  14. Jan 17, 2024 at 1:14 PM
    1SilverRunner
    Tejas
    My last setup was at 3.9 degrees on both sides. Struggled to get them to match until I added lean corrections from OME. Now I can achieve a symmetrical alignment.
    I did bend my cam alignment tabs while wheeling in New Mexico recently. Replaced with Total Chaos gussets. I need to have my alignment checked again.
    Judging by my tire wear I have excessive camber now...
    sam95[OP] likes this.
  15. Jan 17, 2024 at 1:51 PM
    Chillmatic
    Chillmatic New Member
    I have about a 3" lift with SPC UCA and have 3.6 degrees caster out of them. Probably could have gotten more but my father dropped the truck off for me to get alignment since I was working and he forget to tell them to get as close to 4 as possible. So that was what they set on their own. I have no issues so far with them but only 5k miles on them.
  16. Jan 17, 2024 at 2:12 PM
    Big thanks boys
    @1SilverRunner
    @Chillmatic
    Helpful to be mindful of my slight lift lean regarding this.
    And ima book for alignment, and actually talk to a bro there personally for the first time pushing for 4⁰.
    *I heard from smart cookies on here that I actually need to adjust LCA castor to move my wheel any more forward (for future 35" clearance reasons :D)
    1SilverRunner likes this.
  17. Jan 17, 2024 at 2:32 PM
    my current alignment has the 32mm top nut virtually maxed out to the outer side of the slot. The hex retaining plate for castor is set same as before swapping joints, aligned in a straight line with the UCA main body edge. Believe it or not the truck feel almost perfectly aligned from my install cuz I marked everything first.
    TrailSpecial22 and sam95[OP] like this.
