Upgrades finished???
Discussion in '5th Gen 4Runners (2010-2024)' started by billnourse, Oct 12, 2017.
  1. Oct 12, 2017 at 11:25 AM
    billnourse
    billnourse [OP] New Member
    Bill
    Bloomfield, NM
    2017 4Runner TRD Off Road Premium
    Toytec Ultimate lift, SSO Slimline bumper and 10,000# winch, emblem blackout, hood scoop wrap.
    I think I am finished with upgrades. Have Toytec Ultimate at 2.5", running boards, Weather Guard window shields and bug shield, SSO Hybrid bumper with Smittybilt 10,000# winch and Arcadia flip license bracket, Toyo Open Country 265-70-17 tires on stock rims.
    Backslider, Toytec Lifts, Bob and 2 others like this.
  2. Oct 12, 2017 at 11:54 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    Good luck, I have found out that you are never finished.....:thumbsup:
    114616288, jester243 and RainGoat like this.
  3. Oct 14, 2017 at 7:46 PM
    Bob
    Bob Member Staff Member
    Bob
    Looks great. You'll find more to do like @RonT4R said!
  4. Oct 14, 2017 at 11:50 PM
    topdec
    topdec New Member
    2023 4R ORP CSM 2023 Tundra LTD ORP. 2016 4R TE (sold)
    If I were to guess, bigger tires are next, then roof basket.
    Backslider likes this.
  5. Oct 15, 2017 at 8:34 AM
    billnourse
    Bill
    Bloomfield, NM
    No bigger tires. If I had wanted them I would have done so when I put on the Toyo's. 285's are 1" bigger which results in a lift of only 1/2". Don't want to deal with the loss of MPG, change is speedometer, rubbing issues, etc. for 1/2".
    Roof basket could be a consideration, but I don't camp in in it and the things I carry, camera equipment and lights, guns, etc., I don't want in a roof basket. Thuele might be a consideration though.
    Bill
    HarveyElmore likes this.
  6. Oct 15, 2017 at 12:30 PM
    topdec
    topdec New Member
    I also am having a hard time justifying the extra fuel cost and the other factors with going with bigger tires. The black wheel set on my signature is begging to be used.
    How's highway driving after the toyo lift? My stock suspension wanders a little.
  7. Oct 15, 2017 at 4:34 PM
    HarveyElmore
    HarveyElmore New Member
    Harvey
    Offroad TRD 17'
    No issues with the 285's rubbing ?
  8. Oct 17, 2017 at 9:35 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX4(Runner)60
    While I respect your service, I'd dump the front plate. If you actually use the truck off road, and use the winch, that plate and your $150 bracket are going bye bye after one outing. The Cascadia is designed to sit up higher on the bumper - the SSO hybrid bumpers place the winch pretty low.
    Incidentally, 285s in C range really don't cause MPG issues. They also put the speedo exactly accurate - if you compare it with stock tires to GPS, it's actually off by a small amount. Lastly, measured fuel economy with large tires is slightly better than computed because the odometer is uncorrected. When all that is factored in, going up a size in tires is pretty much a wash. I would absolutely get larger tires with a 2.5" lift - otherwise, what was the point of the lift?
  9. Oct 17, 2017 at 10:18 AM
    jester243
    Dan
    Spokane, WA
  10. Oct 17, 2017 at 3:52 PM
    billnourse
    Bill
    Bloomfield, NM
    I have used the winch twice so far with no issues. The plate flips up pretty high and I'd have to really be pulling up to hit it. If I do I'll just loose it.
    The point of the lift was to increase approach and departure angles and the lift accomplished that. I also gained a little over 2" from ground to front skid plate. I really don't see how 1/2" more lift that 285's will give would be that much advantage, but I could change my mind.
  11. Oct 17, 2017 at 4:01 PM
    MeefZah
    Lexington, Ohio
    2020 GX4(Runner)60
    Fair enough!
  12. May 22, 2018 at 7:10 PM
    Dingus_Dave
    Dingus_Dave New Member
    David
    2011 4runner sr5
    Just a heads up bigger tires aren't usually justified for the lift you get from them. Also to the others reading this it isn't 100% technically correct but it's the right idea. A bigger tire adds more momentum and rolling power while off-roading. It makes it easier to roll over bumps because proportionally your diameter of tire is bigger compared to the bump, and although it seems like a small change going to a 285 and getting that 1 inch gain, it actually makes a huge difference in your off-road capability. But I'm not one to call someone out on their opinion, your rig looks so awesome and I love that bumper. P.S. thank you for your service!
  13. Jun 5, 2018 at 9:07 AM
    jgcaps
    jgcaps Lovin the Colorado Life.!
    CO
    2018 MGM TRD ORP KDSS 4Runner
    3" Icon Stage 2, 18x9 Fuel Beast wheels, 285/65/18 BFG KO2's, N-FAB Black Rock Rails w/removable steps.
    Well done... nice rig.!
