Up stream O2 sensor replacement
Discussion in '5th Gen 4Runners (2010-2024)' started by MIKE-E-S, Feb 25, 2024.
  1. Feb 25, 2024 at 12:19 PM
    MIKE-E-S
    MIKE-E-S [OP] New Member
    Minnesota
    2011 4runner SR5 - w/o KDSS
    Working on a 2011 4runner sr5. Has anyone on here successfully changed their up stream 02 sensors? I went in this morning to pull them out and I couldn’t, for the life of me, get to them. They are in a very difficult spot. Any instruction, tips or trick or special tools (besides the o2 socket) that makes this job easier or just doable.
    TIA,
  2. Feb 25, 2024 at 12:29 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
  3. Feb 25, 2024 at 12:44 PM
    MIKE-E-S
    Minnesota
    Thanks Rob41 unfortunately the video only talks about the downstream O2 sensors which are pretty easy to reach.
  4. Feb 25, 2024 at 12:49 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    Bummer. If you don't find out here, please come back and post how you do it. I know from experience, changing O2 sensors on vehicles North of 75k miles (even if well maintained) makes a difference.
    The only thing I can say is they are usually difficult to get out as they are in the exhaust. Use caution, but heat is your friend along with bees wax or another penetrant.
