Truck leaning to the passenger side after lift
Discussion in '5th Gen 4Runners (2010-2024)' started by Yotaholic, Nov 24, 2023.
  1. Nov 24, 2023 at 7:46 PM
    Yotaholic
    Yotaholic [OP] New Member
    Olympia, WA
    Is it my illusion or uneven surface? I will discuss this with the shop next month. I have an apppintment with them for post lift inspection.
    djwantke likes this.
  2. Nov 24, 2023 at 8:23 PM
    Oakboro, N.C
    Visually, it does appear to have a slight difference between right and left, just by the picture, I would definitely document measurements with correct tire pressure and weight to provide to your guys for reference
    Yotaholic[OP] likes this.
  3. Nov 24, 2023 at 8:24 PM
    Yotaholic
    Olympia, WA
    Will do. Can it be fixed if there is an issue? Googled and people talk about the KDSS lean thing. Could it be that?
  4. Nov 24, 2023 at 8:33 PM
    Oakboro, N.C
    Not 100% sure as this is in nowhere in my wheelhouse, but there has to be other 4runners with similar issues. with similar updates.
    Knee jerk reaction, would attribute this to a different spring rate. This is just an opinion on my part.
  5. Nov 24, 2023 at 8:38 PM
    KDSS lean can happen with lift or without lift.
    If the lean is too much to your taste there are multiple solutions shops use.
    1) My 4x4 shop preferred method - open kdss valve method.
    Some shops use-
    2) KDSS spacer (a very common method used)
    3) Different spring (heard for GX460 this method
    If it's not too much I won't mess with it.
    Thatbassguy and Yotaholic[OP] like this.
  6. Nov 24, 2023 at 8:42 PM
    Yotaholic
    Olympia, WA
    Doesn't the Toyota warranty cover kdss lean?
  7. Nov 24, 2023 at 8:45 PM
    Not if they think it's a result of your modifications.
    Hopefully your shop is familiar with KDSS, and maybe it can be fixed by opening the valve.
  8. Nov 24, 2023 at 8:54 PM
    Yotaholic
    Olympia, WA
    But they have to prove that the modifications did it? Did this happen to your kdss when you put the lift on?
  9. Nov 24, 2023 at 8:58 PM
    Yotaholic
    Olympia, WA
    It is a really well made lift kit, not some cheap crap. It is specifically designed for the kdss system,
  10. Nov 24, 2023 at 9:00 PM
    Sort of. The Magnuson Moss act is supposed to protect us from being denied warranty work unless it can be proven that the modification caused the issue. Unfortunately, it doesn't seem to work that way in practice.
    Mine is fine. I kept it around 2.5" in front, and 1.5" in the rear, and it sits level.
    It seems like a crapshoot if you're going to get a lean.
    The KDSS spacers might help, or they might not.
    Yotaholic[QUOTED][OP] likes this.
  11. Nov 24, 2023 at 9:00 PM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    It does look tilted, but so does the white Toyota sedan across from you.
  12. Nov 24, 2023 at 9:03 PM
    Yotaholic
    Olympia, WA
    I'll try to find a level spot and take some measurements
  13. Nov 24, 2023 at 9:09 PM
    Yotaholic
    Olympia, WA
    This is pacific northwest, level spots and level heads are a rarity ;)
    2Toys and Thatbassguy like this.
  14. Nov 24, 2023 at 9:17 PM
    garoto
    garoto New Member
    Hard to say from the photo. Everything in that photo is leaning, therefore nothing is leaning.
  15. Nov 24, 2023 at 9:21 PM
    I don't know anyone got it corrected under warranty.
    On another note, you might be over thinking it. As said, park on a level garage even better after giving some highway miles and then check. If it's not a big difference leave it as is. IMO keeping it reliable not let anyone touching it is best rather than getting it perfect level. My Limited rear has ¾cm difference left to right. I didn't use the trim packer or what ever that thing is called. I don't feel driving it nor visually see it. So if it's not too much don't touch it. IMO.
  16. Nov 24, 2023 at 9:27 PM
    True. When I looked at it the picture seems tilted based on the parking lines and other objects. I think measuring center of the wheel to bottom of the fender might be a better way.
    mrmike7189 and Yotaholic[OP] like this.
  17. Nov 24, 2023 at 9:31 PM
    Yotaholic
    Olympia, WA
    So the truck is fine?
  18. Nov 24, 2023 at 9:36 PM
    I would say measure and see. If it's a minor difference, leave it as is. Enjoy the setup you have. As said I'm really happy for you with the lift and tire size option you went with. Over thinking might not give you peace of mind.
  19. Nov 24, 2023 at 9:37 PM
    garoto
    garoto New Member
    When I straighten the photo. The truck against the grid looks fine.
  20. Nov 24, 2023 at 9:40 PM
    Yotaholic
    Olympia, WA
    Great, thanks
  21. Nov 24, 2023 at 9:57 PM
    Yotaholic
    Olympia, WA
    Looks fine here, almost level surface. I am relieved :yes:
    Look, I am too old now to run after dealerships and shops for warranty and stuff. It is why I bought a Toyota and not another Jeep :)
    mrmike7189, 2Toys, HuskyMike and 2 others like this.
  22. Nov 25, 2023 at 6:34 AM
    bassist
    bassist New Member
    You do need a new rear plate. The numbers fell off yours.
    2Toys and Yotaholic[QUOTED][OP] like this.
  23. Nov 25, 2023 at 11:18 AM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    I get the sentiment, but as soon as the dealership see's the aftermarket lift they will deny it and wash their hands. Magnuson Moss would protect him if he had replaced parts to OE specs (Not lifted), and likely only if professionally installed.
    If you have a look at a recall or TSB from Toyota they often denote it will not apply to a vehicle with parts related to the recall that have been modified.
  24. Nov 27, 2023 at 11:07 AM
    Crank_Mancastle
    Crank_Mancastle Professional Wanker
    Austin
    2016 Trail Premium
    Eibach Pro Truck kit Ironman Pro-forge UCS's Rocktrix RT110'S in bronze, 17x9 Toyo AT3'S 285/70/17
    Check the spring perches on the front shocks to make sure one of them isn't upside down? I had that issue when I first installed my lift, I never even noticed until the person that did my BMC chop caught it and told me.
  25. Nov 27, 2023 at 12:13 PM
    @Yotaholic - did you ever get center of hub to fender edge measurements left/right to compare? That's what will tell you if there is indeed a lean. Then you have to decide if there is, you can live with it as is.
  26. Nov 27, 2023 at 3:12 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Open the kdss valves (if you have them) 1.5-2 turns maximum each. Shake the truck back and forth. It will straighten back out. If you don’t have kdss then my apologies.
  27. Nov 27, 2023 at 9:02 PM
    Sig says KDSS.
    raimieb[QUOTED] likes this.
  28. Nov 27, 2023 at 9:17 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    You may not be overthinking it, I actually have the same lean, often.
    It could be that you're surface you park on regularly; or recent, is at that grade - and the KDSS leans you afterwards. I've flexed all four corners after reading recommendations here, and posted before and after pics.
    Truth be told, I'm convinced I need to install KDSS correction spacers, for the cylinder and panhard correction, it's sold by many (I haven't installed any of the sort, don't crucify me)
  29. Nov 27, 2023 at 9:21 PM
    My centre of wheel to fender measurements are actually,not bad. Adding to the illusion perhaps. But as good folks have mentioned here, I may need to adjust the valves god help me..
  30. Nov 27, 2023 at 9:29 PM
    Yotaholic
    Olympia, WA
    You have a point. The spot where the truck is parked most of the time, is not level. So what's the solution, park the other way for a few days lol?
