troubleshooting 90 4runner no spark
Discussion in '2nd Gen 4Runners (1990-1995)' started by sjenoch, Nov 22, 2022.
  1. Nov 22, 2022 at 9:51 PM
    sjenoch
    sjenoch [OP] New Member
    90 4runner
    Parked the runner after a desert cruise. Went to start a week later, did not start (would crank) and started diagnosing. No spark at the plugs, no spark at the distributor, no spark at the ignitor. Tried to jump the plug to get a code reading, producing no codes to read. Replaced the Ignitor and Module.
    have OHM out the plug wires
    Have checked fuses and relays.
    Have checked grounds
    Anyone have any ideas?
  2. Nov 23, 2022 at 9:53 AM
    Justthemechanic
    Justthemechanic New Member
    Nevada desert
    94 4Runner SR5, 5 speed, 3.0
    OME 2” lift, BudBuilt armor, RRO sliders, Spartan rear locker
    What engine?
    sjenoch[OP] and wildgoose like this.
  3. Nov 23, 2022 at 7:09 PM
    sjenoch
    90 4runner
    the 3.0
  4. Nov 24, 2022 at 10:10 AM
    Justthemechanic
    Nevada desert
  5. Nov 24, 2022 at 11:04 AM
    sjenoch
    90 4runner
    thank you let me run through that and see where i am after working that diagram
  6. Dec 10, 2022 at 3:11 PM
    Waynes
    Waynes New Member
    1995 4runner 3vze
    on my rig, when I was faced with this issue, it was the distributor. It is where the ECM gets the signal that tells the program how to send the spark from the ignitor. Do you have a check engine light when the ignition switch is on but not trying to start? If so, the
    ECM is not dead...
