TRD Pro shocks backwards
Discussion in 'Suspension' started by User2674, Jul 18, 2023.
  1. Jul 18, 2023 at 9:18 AM
    User2674
    User2674 [OP] New Member
    2015 4runner trd pro
    I have a 2015 4runner trd pro and I realized the shocks are installed backwards. When I swap the shocks to the correct side should the driver side be up higher? Currently the passenger side is about 1/2" higher. Or should they be set the same? It also has a small clunk while driving but I think thats a separate issue.
  2. Jul 18, 2023 at 9:24 AM
    Crikeymike
    Crikeymike Exit Offroad, Dobinsons Specialist Vendor
    Jax Beach, FL
    2014 4Runner w/Dobinsons MRA Suspension, Shrockworks bumper/sliders
    On non-KDSS vehicles, the taller one goes on the driver's side.
    A clunk is usually loose sway bar links FYI
    HuskyMike and beedee like this.
  3. Jul 18, 2023 at 9:33 AM
    User2674
    Sway bar links are cheap I like that answer lol. Thank you
  4. Jul 18, 2023 at 12:22 PM
    User2674
    But I guess the next question would be is it true that the driver side and passenger side have different valving inside? Cause if the shock is the same couldn't I just move the ring to change the height and not have to tear everything apart?
  5. Jul 18, 2023 at 12:31 PM
    Crikeymike
    Jax Beach, FL
    They are the same, but to change that ring height, you need to disassemble the strut or at least compress the coil. It's easier/faster to swap them left to right
