Transmission pausing, losing power, not shifting properly
Discussion in '4th Gen 4Runners (2003-2009)' started by paulgimenez, Jun 15, 2023.
  1. Jun 15, 2023 at 2:48 PM
    paulgimenez
    paulgimenez [OP] New Member
    Paul
    2004 4runner Ltd
    It is my first Toyota and was purchased after Hurricane Irma totaled all my cars in one night. Its ran great until the transmission started to "pause" periodically while in use. Losing power, not shifting unless done manually. Given the hilly terrain around here not a good thing. So a little research identified 3 shift solenoids that should be changed including a 3way solenoid. No. 1 was what rock auto had it fit but the connector was black and did not work. The original solenoid has a brown connector and a two screw plate on the left side (back aspect). I have not been able to find the same solenoid anywhere on line in the U.S. Does anyone know if I am looking for the wrong part?
  2. Jun 15, 2023 at 3:01 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    This forum is for 2010-2024.
    08TXRunner likes this.
  3. Jun 15, 2023 at 3:30 PM
    paulgimenez
    Paul
    2004 4runner Ltd
    OK thanks for the heads-up. I will move it to the 4th Gen forum.
    Rocko9999 likes this.
  4. Jun 15, 2023 at 4:11 PM
    Bob
    Bob Member Staff Member
    Bob
    Moved
  5. Jun 15, 2023 at 7:58 PM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    Several things are missing from the provided information.
    Year: 2004 Limited
    Engine: ?
    4WD or 2WD?
