Transmission or transfer case problem?? Need help
Discussion in '2nd Gen 4Runners (1990-1995)' started by debbie1818, Aug 13, 2018.
  1. Aug 13, 2018 at 5:49 AM
    debbie1818
    debbie1818 [OP] New Member
    DEBBIE
    1990 4RUNNER
    Looking for help, not sure if I have a transmission or a tranfer case problem. I have a 1990 toyota 4 runner automatic trans v6 4 wheel drive. Vehicle ran good til it was parked then next day truck won't move when put in to drive. It moves a very little when in 2 drive.No reverse, no 4 wheel high but when you put it in 4 wheel low it moves like it should and shifts in 4 low like it should. Anyone know if its a transmission problem or a transfer case problem? Also reverse works in 4 wheel low. Fluids are good.
  2. May 21, 2021 at 2:30 PM
    tbhudson92
    tbhudson92 New Member
    Tom
    1995 4Runner 3.0
    Did you ever figure out the problem? I'm having the same issue right now.
  3. May 22, 2021 at 8:01 PM
    mostlystock93
    mostlystock93 New Member
    93 4runner 3vze 4WD, Ellsworth Enlightenment 29er
    slight lift, aftermarket headers, cold air intake
    Mine stopped shifting and I had to decide to do a swap with a used one, sell it or rebuild the tranny. I rebuilt it!
  4. May 22, 2021 at 8:16 PM
    tbhudson92
    Tom
    1995 4Runner 3.0
    Gotcha! We’re you having the same problem with the truck barely moving in 2H?
  5. May 24, 2021 at 1:58 AM
    Pyroslinger
    Pyroslinger 1995 Hi-Lux Surf 3.0 3VZE Factory 250,000
    Pyroslinger
    Montana
    1995 Hi-Lux Surf SR-5 3.0 3VZE / Bought at 29,000 - Present 250,000/ Rusted Body, Excellent Otherwise
    Factory/ 2" Ol Man Emu Rear Springs/ Skyjacker Shocks/ Cat- Back Exaust/ K&N Air Filter/ Denso Iridium Plugs/Neoprene Vacume Lines/Sony CD Head Unit+Focal Factory Fit Speakers
    Oh my God!!:bananadead: Try the full 5 gallon Dex-Merc flush.....what the hell. Also...there is a "can" under the passenger fender well...if that dam vacume line is cracked or off...or a hole in the can...4WD wont work and could cause the symptoms you described. Best Of Luck!! P.S.
