Transmission issues with my 2019 SR5
Discussion in '5th Gen 4Runners (2010-2024)' started by PJ4Runner, Jul 25, 2024.
  1. Jul 25, 2024 at 1:59 PM
    PJ4Runner
    PJ4Runner [OP] New Member
    2019 4Runner SR5
    When shifting into DRIVE the transmission sits in NEUTRAL for approximately 5 seconds then it kicks into drive. Doesn't happen all the time- very inconsistent. Toyota dealership said needs new transmission and switch assembly- approximately $6700. Any thoughts or suggestions?
  2. Jul 25, 2024 at 2:09 PM
    Texoma-Brad
    Texoma-Brad OK Yota
    Brad
    Texoma USA
    Depends on a lot of factors.
    Let's start with how many miles are on the SR5?
  3. Jul 25, 2024 at 2:36 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Why? I have 185K on my 2011 and if it needed a new transmission I would probably do it. Not at the dealer, mind you. No matter what it's better than forking over $50K for a new 4R.
  4. Jul 25, 2024 at 2:48 PM
    I'm thinking low fluid level.
  5. Jul 25, 2024 at 2:52 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    I hate to ask the obvious, but as @whippersnapper02 said, did you check to make sure it has the proper amount of fluid?
    whippersnapper02 likes this.
  6. Jul 25, 2024 at 3:09 PM
    BLKNBLU
    BLKNBLU New Member
    2019 TRD OR Nauti Blue
    And we're back to Texoma's question.
    How many miles?
    Then my question. To your knowledge has the fluid ever been serviced/changed?
  7. Jul 25, 2024 at 3:19 PM
    scanny
    scanny New Member
    Ontario, Canada
    could be neutral switch on transmission, usually is rusts out after about 5-7 years and make shifting to drive inconsistent. If transmission wasn't abused too much and serviced on regular intervals as per manual it would be highly unusual that transmission needs replacement. Does OBD scanner show any codes?
  8. Jul 25, 2024 at 5:31 PM
    PJ4Runner
    2019 4Runner SR5
    47,300 miles. Transmission fluid checked- was low a quart but was topped off. Problem still exists.
  9. Jul 25, 2024 at 5:36 PM
    PJ4Runner
    2019 4Runner SR5
    47,300
  10. Jul 25, 2024 at 5:38 PM
    PJ4Runner
    2019 4Runner SR5
    No codes and fluid topped off- was low a quart.
  11. Jul 26, 2024 at 2:19 AM
    ATL4R
    ATL4R New Member
    2024 Limited
    Are you not still covered under the powertrain warranty?
  12. Jul 26, 2024 at 6:03 AM
    PJ4Runner
    2019 4Runner SR5
    No. Powertrain warranty expires 8 months ago. I have contacted Toyota Cares to see if they can work with me.
  13. Jul 26, 2024 at 6:08 AM
    ATL4R
    ATL4R New Member
    2024 Limited
    I was going to recommend that. I had a 4th gen out of warranty with a timing cover leak. They offered to pay 50% of the bill. I don’t remember exactly who I contacted then, just the number for Toyota USA/North America. Good luck.
  14. Jul 26, 2024 at 8:24 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Hmm, a quart low?
    How was that determined?
    Was the proper fill check method done at temperature?
    2Toys likes this.
  15. Jul 26, 2024 at 10:28 AM
    PJ4Runner
    2019 4Runner SR5
    Local Toyota dealership did a multipoint inspection and also checked transmission fluid- based on what I informed them was happening with my 4Runner.
  16. Jul 26, 2024 at 11:24 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    If you’re the original owner, and there has been no leak, I’d suspect the original factory fill was low.
    Or if the previous owner did a transmission fluid change they could have underfilled it.
    In either case if it was driven a lot with low fluid there could be serious damage done.
    Hopefully Toyota will help you out with this. Good luck. :thumbsup:
  17. Sep 14, 2024 at 10:33 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    Check fluid level and linkage adjustment for shifter
