Transmission flush
Discussion in '5th Gen 4Runners (2010-2024)' started by Az4runnerTom, May 9, 2023.
  1. May 9, 2023 at 6:30 PM
    Az4runnerTom
    Az4runnerTom [OP] New Member
    Stock Red 2014 4runner
    I bought a used 4Runner a few months ago and it just hit 100k miles.
    I have no idea if the transmission has ever been serviced and I’m afraid to do a full drain since the mileage is on the high side. Car care nut recommends not doing a full flush unless it has always been done at regular intervals of 60,000
    has anybody done their first flush after 100k with no issues?
    I did see there is a thread covering this topic, but nobody mention when they first drained the fluid
  2. May 9, 2023 at 6:39 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    You must have missed the other 4,572 threads on this topic.
    Rocko9999 and Mtbpsych like this.
  3. May 9, 2023 at 7:03 PM
    Stoney Ranger
    Stoney Ranger New Member
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-Fr/R Bpr-Winch-Stickers-ALF
  4. May 9, 2023 at 8:25 PM
    CygnusX-4
    CygnusX-4 Member
    21 TRD OR
    If that were mine, I would just drain it and refill it. I wouldn't be afraid to flush if you trust the person doing it, if that's what you want. Ford Explorer? Different story...
    Mtbpsych likes this.
  5. May 9, 2023 at 8:39 PM
    Stitches1974
    Stitches1974 New Member
    2023 Nautical Blue TRD ORP
    It has less to do with the person doing the flush, but the junk in the transmission that can loosen up and kill it. I did flushes on vehicles for a few years. If a vehicle came in and needed a flush with high miles and no history of one getting done, we had to read them the riot act about what can happen to their transmission and would not be held liable for any damage caused. I agree with you on a drain and fill only.
    I've seen both ends of what can or can't happen. Vehicles ( with no flushes ever done ) with high miles ( 100-200K + ) flush fine with no issues, to transmissions with under 100k miles crap out 3 days after the service.
  6. May 9, 2023 at 9:01 PM
    CygnusX-4
    CygnusX-4 Member
    21 TRD OR
    I understand all that and very valid points. Have you seen a flush kill a 5th gen 4Runner with 100k?
    Stitches1974[QUOTED] likes this.
  7. May 9, 2023 at 9:05 PM
    Mtbpsych
    Mtbpsych New Member
    Drain and refill for me.
  8. May 9, 2023 at 9:06 PM
    Stitches1974
    No, but I'm not saying it can't happen either. Retired and have not worked on a car in almost 20 years.
    CygnusX-4[QUOTED] likes this.
  9. May 9, 2023 at 9:09 PM
    Az4runnerTom
    More like a ford exploder
  10. May 9, 2023 at 9:11 PM
    Az4runnerTom
    I guess it’s just safer to drain and refill. I want to prolong the life of the transmission but I don’t want to ruin it either. Too bad we can’t manual swap these things
  11. May 9, 2023 at 9:13 PM
    Az4runnerTom
    I suppose a drain and refill is better than doing nothing
  12. May 9, 2023 at 9:13 PM
    CygnusX-4
    CygnusX-4 Member
    21 TRD OR
    Well, I was trying to play nice..:D
  13. May 9, 2023 at 9:16 PM
    Stitches1974
    If it were mine, drain and fill only.
  14. May 9, 2023 at 9:19 PM
    Az4runnerTom
    I gotta hand it to Ford though… their 90’s trucks are decent. I had a 96 van with 410k miles and a 99 F150 with 288k.
  15. May 9, 2023 at 9:20 PM
    Az4runnerTom
  16. May 9, 2023 at 9:52 PM
    steelevo
    Utah
    Welcome. Drain and fill is the route I would take.
  17. May 10, 2023 at 5:15 AM
    Sailormilan2
    Sailormilan2 New Member
    Dale
    2020 4Runner TRD Premium
    OP. I did the "drain the pan, refill the pan, pump out the old fluid, refill, repeat" at 90k miles on my Tacoma. Fluid was absolutely black. after the drain and refill it was dark cherry red. After that was done, I installed a Purolater P1320 inline transmission filter on the trans return line from the radiator. I've now changed the filter twice at 30K miles intervals. Fluid is back to the proper red color. I'm not going to worry about the pan "filter" as it's more of a screen than a filter. Besides, it's much easier to change the inline filter than clean the pan screen.
  18. May 10, 2023 at 7:29 AM
    Stitches1974
    The Ford 300 straight six was a beast of a motor. An army buddy of mine had one. He just couldn't kill it.
    rickystl likes this.
  19. May 10, 2023 at 8:07 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Ripper238 likes this.
  20. May 10, 2023 at 8:14 AM
    Az4runnerTom
    Lol
    Rocko9999[QUOTED] likes this.
  21. May 11, 2023 at 4:43 AM
    j cat
    j cat New Member
    massachusetts
    spacer lift front 1inch
    The 4runner is transmission fluid and the filter ,pan cleaned it around 80K-100K miles ...the towing is 40-60K miles fluid changed it ....the plug of the fluid level 110F transmission temp.....I was the scan tool of the temp fluid ...
    I did the GM transmissions dexron III fluid and it updated it dexron VI ... I did the 40K miles fluid ...
  22. May 12, 2023 at 10:12 AM
    rickystl
    rickystl New Member
    Rick
    St. Louis, MO
    2021 TRD/Off-Road Premium
    My brother owned a 77 Ford pickup with that same 300 inline six and a manual 4-speed. Couldn't destroy it. In the 60's they also made a 352 V-8 with similar longevity. I believe Ford originally built both as truck engines.
  23. May 12, 2023 at 10:45 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Just drain and fill. All my cars that lasted I only did a drain and fill or nothing at all.
    Rocko9999 likes this.
  24. May 12, 2023 at 10:55 AM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    I have done both and never had transmission issues. My 2003 Tacoma has a dipstick and will do a drain and fill every couple oil changes. Still bright cherry red with 200k miles. My Lexus LS430 I did several flushes starting at 60k and again every 30k. Fresh fluid is cheap insurance for me on not causing transmission to fail.
