Transimission problems
Discussion in '4th Gen 4Runners (2003-2009)' started by Pinstriped.4g, Mar 4, 2024.
  1. Mar 4, 2024 at 12:48 PM
    Pinstriped.4g
    Pinstriped.4g [OP] New Member
    Sam
    2006 Silver 4Runner
    A few weeks ago when i was driving home from the ski hill i started running into some transmission issues. My car had problems shifting at all, only shifting between 2nd and 3rd gear. Since then I have completely lost 2nd gear and can only drive it in 3rd gear as it will not shift from there (not that i am driving it much because of the problem).
    I finally got around to scanning te engine and it did throw a "couple" codes. 10 that delt with the transmission directly.
    P0713
    Transmission fluid temperature sensor
    A circuit high
    P0748
    Pressure control solenoid a
    Electrical
    P0776
    Pressure control solenoid B
    Performance stuck/off
    P0778
    Electrical
    P0974
    Shift solenoid A
    Control circuit high
    P0997
    Shift solenoid B
    P0986
    Shift solenoid E
    P2716
    Pressure control solenoid D
    Electrical
    P2743
    Transmission fluid temp sensor
    B circuit high
    P2759
    Torque converter
    Is this going to be a full transmission replacement issue? or is it possible to save it still by just replacing solenoids.
  2. Mar 4, 2024 at 2:59 PM
    Did you check your fluid level?
    RumHamRunner73 likes this.
  3. Mar 5, 2024 at 11:46 AM
    Pinstriped.4g
    Sam
    2006 Silver 4Runner
    Yes my fluid level is fine.
  4. Mar 5, 2024 at 1:25 PM
    Well, have to check the simple things first.
    This has a TCM? I would check the wiring to it and all power and grounds. That's a whole bunch of codes to get all at once.
  5. Mar 5, 2024 at 2:00 PM
    Oakboro, N.C
    Welcome to the forum!
    May be outta this universe, I would do a quick visual on the harness(s) to ensure no malicious intent from rodents looking for something to naw on.
  6. Mar 6, 2024 at 2:41 AM
    Welcome from Wisconsin!
