Traction control operation
Discussion in '5th Gen 4Runners (2010-2024)' started by Tmiesowicz, Mar 27, 2022.
  1. Mar 27, 2022 at 3:58 AM
    Tmiesowicz
    Tmiesowicz [OP] New Member
    The better half of New York
    It was snowing today and was the first time I really drove my 4 runner in the snow, in 2 wheel drive. I turned off the traction control or ‘VSC’ system & felt like abs or another kind of traction system was operating. The traction control turned its self back on. I turned it off again driving down a road with no slippage, and it activated its self again. Is this normal? First vehicle with traction control and such. Thought turning it off would keep it off until I commanded it back on or restarted the vehicle. Thanks.
  2. Mar 27, 2022 at 5:39 AM
    WarTurtle357
    WarTurtle357 You're killing me, Smalls.
    Land of 10,000 Potholes
    2022 MGM ORP
    I think if you turn off TRAC with a button push (VSC will stay on), it re-engages above a certain speed. If you want to completely shut it off. Hold the button for 3 seconds while stopped, and it should turn off both TRAC and VSC until you push the button again or turn off you 4Runner.
  3. Mar 27, 2022 at 6:02 AM
    Tmiesowicz
    By trac do you mean a-trac? On the above head console I have the VSC button, then A-TRAC (to my understanding this does nothing unless you are in 4 LOW) I hit that button and it did nothing in 2 wheel drive. So would I hold down the VSC or A Trac for 3 seconds. I have to go outside and try this out. Thank you. These are the options I have.
  4. Mar 27, 2022 at 6:16 AM
    It's the "off" switch you want to hold down. As mentioned, be completely stopped. "Trac off" will pop up on the dash right away. Keep holding it until "VSC off" pops up. Then, you're free to go do donuts. :burnrubber:
  5. Mar 27, 2022 at 7:36 AM
    WarTurtle357
    2022 MGM ORP
    Hold the VSC Button. A-TRAC is for 4LOW like you said.
    :mudding:
  6. Mar 27, 2022 at 8:07 AM
    Tmiesowicz
    Thank you guys, I’m going to try this when I leave work...I found it real dumb how it kept coming back on. All vehicles I ever drove if you hit it off it stayed that way. I am new to the Toyota / electronics world coming from a vehicle with no traction control at all.
  7. Sep 4, 2023 at 12:19 AM
    pastoreater
    pastoreater New Member
    2023 sr5 2wd toyo 115T
    Edit. confused to an extent because havent driven hard enough to feel stability control
    It's the VSC off light which illuminates immediately and then the TRAC OFF light that illuminates after holding while stopped.
  8. Sep 4, 2023 at 4:24 AM
    Not on my 2019. Maybe they changed it. :notsure:
    Screenshots from a video I just took out of curiosity:
    1st:
    Second:
    pastoreater[QUOTED] likes this.
  9. Sep 4, 2023 at 8:59 AM
    pastoreater
    That's wild Thatbassguy. It might be a 2wd thing, I need to triple check this i guess. I have a toyota car that goes VSC off after long press and I believe lexus ls430 is also vsc off after long press. I got into a dirt lot to :mudding: the ls430 and had to leave because I couldn't control it at all
    but in my rig the picture on the button is indeed vsc off icon. In my car the button is trac off.
    edit. Just confused to an extent because havent driven hard enough to feel stability control
  10. Sep 4, 2023 at 9:27 AM
    I wouldn’t want to do donuts in such a top heavy vehicle and one tire fire.
    RumHamRunner73 and pastoreater like this.
  11. Sep 4, 2023 at 9:40 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Lock the rear diff!
  12. Sep 4, 2023 at 9:41 AM
    It only works in 4wd low range.
  13. Sep 4, 2023 at 9:45 AM
    Ripper238
    2019 TRD OR
    O yeah, that's right.
    So the consensus is if VSC is pressed and held down its off, not just pressing it.
  14. Sep 4, 2023 at 9:47 AM
    Yes, that’s how it’s been for a while now. My 2010 Tacoma worked this way. However it lurks in the background even when it shows off. If you get too crazy, it will jump back in.
    djwantke and Ripper238[QUOTED] like this.
  15. Sep 4, 2023 at 10:05 AM
    I only do it in snow. Not really "donuts" in this case, but I had to make a proper entrance. :burnrubber:
    Edit: also, if you add enough weight down low, it's not as top heavy. ;)
  16. Sep 4, 2023 at 12:12 PM
    pastoreater
    I hear you, but I also wonder if Toyota put a solid center stripe on the dunlops for a reason:hungry:
    also, not totally figured this out yet, but 1 press puts my rig VSC off, so I wonder if the still active traction control will brake my inside wheel
  17. Sep 4, 2023 at 12:40 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    It doesn't appear to do that in 4LO. In my off-roading course, they hung us up on diagonals and tried to get stability control to kick in automatically at very low speeds, which they said a Wrangler will do. After about four failed attempts, I engaged ATRAC, which worked like a charm. I think the other 4Runner used ATRAC right off the bat, judging by the video of his wheels. (What they said about the Wrangler is that in 4LO, the VSC is extremely desensitized, but not completely disabled.)
  18. Sep 4, 2023 at 12:41 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Can ya'll explain if 5th gen 4R's are actually one tire fire, or if both rear wheels get varying amounts of power?
    Also same question when in 4WD what happens at the front axle? (I am aware of the power ratio split between rear and front, but what about when talking about each tire). Thx!
  19. Sep 4, 2023 at 12:45 PM
    It’s an open diff so power will travel to the tire with the least resistance. Turn and mash it and the inside tire will spin for days. In 4wd both open diffs will do the same which is why you get ony one front tire and one rear tire to spin. The traction system tries to transfer power with the brakes but it’s limited.
    Lock up the rear end and you get power to both wheels at all times.
    The Limited’s center diff will transfer as much power as it can to both axles in full time 4wd. I believe the max is 40% front and 60% rear until the user locks it.
  20. Sep 4, 2023 at 1:01 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Locking diff only works in 4 lo?
  21. Sep 4, 2023 at 1:03 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Just wanted to say thank you.
    I've been. Pressing that button and it's clearly not completely off so I can't do doughnuts in the mud and snow and sand and this has been my least forcorite bit on the car. Didn't know you has to hold it down. Going to have more fun now thank you!
  22. Sep 4, 2023 at 1:05 PM
    From the factory, yes.
  23. Sep 4, 2023 at 1:05 PM
    This information is in the manual, also. ;)
    Thacrow[QUOTED] likes this.
  24. Sep 4, 2023 at 1:05 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Admittedly I don't do that. But I sincerely appreciate those of you that do.
  25. Sep 4, 2023 at 1:06 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    This is hilarious. I've clicked on my rear diff lock soooooooo many times in 2wd and 4 hi. It's seriously not doing anything?
  26. Sep 4, 2023 at 1:10 PM
    Absolute nothing. Flashing means it’s not locked.
  27. Sep 4, 2023 at 1:15 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    The power of the placebo affect. Well thank you this has been a most productive day.
    I think I need to open my owners manual for the first time.
    icebear, ChessGuy and pastoreater like this.
  28. Sep 4, 2023 at 1:17 PM
    pastoreater
    Just get the pic of the car with squiggly tiretrack illuminated solid on your dash and you can get full(?) power with the wheel turned
    At least that's how other toyotas are I haven't done this yet with 4r
  29. Sep 4, 2023 at 1:21 PM
    You really should because then you find out things like the HVAC system will auto open the fresh air if it gets hot enough and how in a 2nd gen Tacoma you can push and hold the recirc button to bypass it from auto opening. :laser:
  30. Sep 4, 2023 at 11:21 PM
    pastoreater
    vsc off auto lsd (lol) on one touch and vsc off trac off on hold. IMG_8412.jpg
    Thacrow likes this.
