Traction Control light flashing on long turns
Discussion in '2nd Gen 4Runners (1990-1995)' started by keolakehau, Feb 1, 2019.
  1. Feb 1, 2019 at 6:43 PM
    keolakehau
    keolakehau [OP] New Member
    Brian
    02 4Runner
    Traction control light flashes and vehicle starts getting weird on long sweeping turns, mostly on freeway off ramps. Anyone know how to fix the problem
  2. Feb 1, 2019 at 7:25 PM
    WallyT4R
    WallyT4R New Member
    Is the vehicle losing traction when this happens? Excessive speed?
  3. Feb 2, 2019 at 6:00 PM
    keolakehau
    Brian
    02 4Runner
    Seems like one wheel brakes to gain traction. Truck swerved a little that moment. Is there sensors that may need servicing or replaced? Speed about 35mph. Spooky when you’re not expecting it. Now I grab the wheel a little firmer when making those turns.
  4. Feb 2, 2019 at 8:11 PM
    4runningMan
    4runningMan New Member
    New Mexico
    It it totally stock? No mods?
  5. Feb 2, 2019 at 10:58 PM
    WallyT4R
    WallyT4R New Member
    Sounds like you may have been driving with excessive speed around a corner and your traction control kicked on probably saving you from losing control.
  6. Feb 2, 2019 at 11:55 PM
    keolakehau
    Brian
    02 4Runner
    Stock except a 2” leveling McPherson’s strut in the front
  7. Feb 2, 2019 at 11:59 PM
    keolakehau
    Brian
    02 4Runner
    But wasn’t going fast on the turn. 35-40 max. And it was a sweeping turn. Safe speed for those turns. May need to check the sensors, like you said though. I didn’t know I had any wheel sensors
  8. Feb 3, 2019 at 12:09 AM
    4runningMan
    New Mexico
    A VSC recalibration *might* fix your problem.
  9. Feb 3, 2019 at 4:31 PM
    Old Man 4x4
    Old Man 4x4 New Member
    2007 4 Runner
    Check your wheel bearings. Too much play causes the anti-lock to not read correctly. Traction control is tied into the anti-lock system. Just a possibility.
    keolakehau[OP] likes this.
  10. Feb 3, 2019 at 9:48 PM
    WallyT4R
    WallyT4R New Member
    Could have been oil or something on the road that caused a wheel to trip the system.
