TPMS replacement options
Discussion in '5th Gen 4Runners (2010-2024)' started by Nostod, Jan 1, 2022.
  1. Jan 1, 2022 at 6:27 PM
    Nostod
    Nostod [OP] New Member
    Aaron
    2017 4Runner SR5 Premium
    Hey everyone. I just moved to an area that gets pretty gnarly weather. I was looking into getting a spare set of rims and throwing some snow tires on them. The issue I am running into is finding wheels without the TPMS in them. Was wondering if any of you have had any luck finding the new TPMS for not a huge chunk of change? Thanks in advance.
  2. Jan 1, 2022 at 10:11 PM
    HornedOwl
    HornedOwl New Member
    Washington State
  3. Jan 3, 2022 at 1:44 PM
    Nostod
    Aaron
    Right on, thank you. I actually found a set of stock wheels with the sensors still on them. That's a good site to know for sure
    HornedOwl likes this.
  4. Jan 3, 2022 at 4:14 PM
    7harper7
    7harper7 New Member
    2022 AG TRD ORP
    Let me know how they work and if they display pressure as the 2022's take a different TPMS, which is programable from behind the wheel. They take a PMV-E000 rather then the PMV-C015 that the 20-21's had. All pre 2020 4runners that take a TPMS, had PMV-107J that didn't display each individual tire's pressure .
    Here is the pic of the one that I took just out of my 22 ORP if it uploads20211126_164252-2.jpg
    xoxrnr, toy33, meowKittieh and 2 others like this.
  5. Jan 5, 2022 at 4:43 AM
    universalfrost
    universalfrost New Member
    Joseph
    Belpre, Ohio
    Predator bars, blackout emblems, TRD Pro Wheels, Falken AT3W tires
    following... im still waiting on my new TRD black wheels and was looking at just getting the factory TPMS sensors for the new wheels / tires (falken wildpeaks for the winter tires)... looking to keep factory tires and wheels for summer and road only and the trd/falken combo for winter/off road
  6. Jan 5, 2022 at 4:48 PM
    HornedOwl
    Washington State
    If I can recommend - https://www.amazon.com/gp/product/B00CXSVODO?ie=UTF8
  7. Jan 5, 2022 at 5:04 PM
    7harper7
    7harper7 New Member
    2022 AG TRD ORP
    The 22's and I believe the 20-21's came with rubber stems like this instead of the Silver aluminum ones used previously. Not sure if these are the right ones but they look just like it.
    https://www.amazon.com/ACCRETION-20...er+tpms+valve+stem,automotive,224&sr=1-5&th=1
    I watched the Discount tire guy use a tool to thread on to the stem and pull it through the rim and then a small screw(they were #10 torx) to attach the actual tpms unit when they put them on my Method wheels.
  8. Jan 5, 2022 at 5:30 PM
    HornedOwl
    Washington State
    Interesting, didn't know they changed it up. Mine is a 20 and had the silver nuts
  9. Feb 5, 2022 at 1:01 AM
    stryderlis
    stryderlis New Member
    ‘22 Lunar Rock TRD ORP
    Just wondering, will the silver 20-21 tpms work with the 22 ORP? Is it the same and the only difference is the valve stem?
    I'm going to be putting TRD Pro wheels on soon and would like to keep my old wheels and TPMS for the winter. I'll probably put some Blizzaks on that setup.
  10. Feb 5, 2022 at 6:37 AM
    TRDLE
    TRDLE New Member
    Duluth, MN
    '22 TRD Pro
    So if I get snow tires, I can get these TPMS sensors, and then update them between seasons from behind the dash?
  11. Feb 5, 2022 at 7:25 AM
    stryderlis
    Yes - in the dash there’s a screen where you can reset and relearn the tpms. I think the only issue, which tpms sensor do we need to get? For 2022 the tpms valve stems are rubber and 20-21 the valve stems are aluminum. I’m not sure if there’s a difference internally or are they interchangeable as starting in 20 is when we can reset and relearn tpms sensors in the 4Runner.
    TRDLE[QUOTED] likes this.
  12. Feb 5, 2022 at 11:41 AM
    stryderlis
    It looks like this is the one. It looks like the same one on my ORP.
    https://www.ebay.com/itm/1-NEW-OEM-Toyota-42607-02050-Tire-Pressure-Sensors-/185271968222
  13. Mar 1, 2022 at 5:14 AM
    universalfrost
    Joseph
    Belpre, Ohio
    bam whole sale has the OEM sensors for about 65 each... that is also who i ordered the wheels from.. .but im still waiting since november... im about to switch to the gunmetal gray wheels if they dont ship by mid march
  14. Mar 21, 2022 at 12:10 AM
    Potsie
    Potsie New Member
    2022 Army Green 4Runner ORP
    Just ordered a wheels,tires and sensors from tirerack for my 2022. They'll come mounted and balanced. I'm hoping I don't have to purchase a scan tool. If I do lesson learned. The sensors were about 42$each
  15. Mar 24, 2022 at 8:34 PM
    Curlystooge
    Curlystooge Member
    2022 limited in magnetic grey
    Newbie, excuse ignorance please, got a 2022 limited on order. Will it have individual tire pressures shown on the display, or just a light if below pressure without showing which tire?
  16. Mar 24, 2022 at 8:37 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    individual read out for each tire except spare
  17. Mar 24, 2022 at 9:04 PM
    Curlystooge
    Curlystooge Member
    Excellent, thank you.
  18. May 26, 2022 at 3:31 PM
    Kthxbai
    Kthxbai New Member
    I believe the Limited actually has a full wheel + TPMS as the Spare.
  19. Oct 17, 2023 at 7:56 PM
    STrooper
    STrooper Let’s Go Places!
    Jack
    Hey guys, sorry to revive this thread. I just got a new set of wheels from a 2022 TRD Off Road and it did came with the new TPMS sensors that has the rubber stems instead of the Silver aluminum ones.
    Does anyone knows if they can be reprogrammed to a 2019 4R?
  20. Oct 18, 2023 at 8:21 AM
    STrooper
    Jack
    No one knows if this is possible?
  21. Mar 3, 2024 at 1:48 PM
    Steve40th
    Steve40th New Member
    sTEVE
    I know this is old, but I would like to know
