TPMS Light
Discussion in '5th Gen 4Runners (2010-2024)' started by skistoy, Sep 13, 2022.
  1. Sep 13, 2022 at 8:52 PM
    skistoy
    skistoy [OP] New Member
    2022 Lunar Rock Trail Edition
    BFG KO2
    At 32 psi I still get the TPMS light. It will then go off, but later back on. Is there any way to reset the parameter of the newer system? We dont have the old reset button
  2. Sep 13, 2022 at 9:02 PM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    In the settings menu in the instrument cluster, under vehicle settings, there is an option for TPWS reset.
    Spare Parts likes this.
  3. Sep 13, 2022 at 9:08 PM
    Check page 438 of your manual. You’ll be using the multi-information display and steering wheel buttons to do the reset.
  4. Sep 13, 2022 at 9:10 PM
    Bodie the Dog
    Bodie the Dog Danger Ranger!
    2016 TEP, 1994 SR5
    Shrockworks sliders & rear bumper, Toytec 3/2 lift, ARB diff mod, 8 pod RGB LED's, RCI steel front skids, Big Sky katana rack, Reese roof rack, cool stickers.
    Also check to see if your spare has a TPMS in it, then check its air pressure if so.
  5. Sep 14, 2022 at 10:24 AM
    Overland WT
    Overland WT Grumpy Old Guy
    Bryan
    West Texas
    2017 TRD Off Road
    Many with many more to go
    What time of day did you measure psi? Remember when tires are cold, it will read lower than later in the day and after driving, it will read higher. Use a manual gauge and measure psi in every tire first thing in the morning and again later in the day after a drive. I've had marginal luck with digital.
  6. Sep 14, 2022 at 10:40 AM
    Potsie
    Potsie New Member
    2022 Army Green 4Runner ORP
    On a similar note my 22 doesn't always load up information on tire pressure. Sometimes it takes a minute or two after start up to read. Im not sure if that's normal or not but since it eventually loads up I assumed it was normal.
  7. Sep 18, 2022 at 8:49 PM
    skistoy
    BFG KO2
    Thanky you . Found it
    TrueTexas likes this.
