Toyota Oil Filter Tested
Discussion in 'General 4Runner Talk' started by Trekker, Feb 11, 2024.
  1. Feb 11, 2024 at 1:24 PM
    Trekker
    Trekker [OP] Regular Member
    1997 3rz 5spd
    This guy uses the same standardized oil and dust in his tests that the companies would use to test their products or equipment. The Toyota filter in the test is the 90915-YZZD1, which goes to 3rz, 5VZ, and probably 1GR that use spin on filters.
    I must say it was a disappointing performance by Toyota. When I saw that it had way better flow than the other filters, I knew it wasn't going to do a good job filtering. It even did worse than the Fram orange can of death.
    While in the video the high capacity of the Toyota filter is shown as a good thing, it's not. The high capacity means the Toyota filter wasn't removing the fine particles, so more dust needed to be added to make it clog. If it was better at removing stuff, it would clog sooner.
    Toyota already knows this and decided it was good enough. I'd still buy it over a budget filter like a Fram orange, at least you know the quality will be good. But there are better filters for not much more money that do way better.
