Toyota Marketing Going All In
Discussion in '6th Gen 4Runners (2025+)' started by 4R777, Jun 1, 2023.
  1. Jun 1, 2023 at 8:34 AM
    4R777
    4R777 [OP] New Member
  2. Jun 1, 2023 at 9:21 AM
    Agreed!
    I watched one of the new Tacoma videos, and it looks really good to me. The turbo 4, if it ends up being reliable, looks like a huge upgrade from the 2GR-FKS. As far as power, it's going to be a significant improvement from the 1GR, as well.
    I am much more excited about the 6th gen 4Runner now that the Tacoma has been announced!
  3. Jun 1, 2023 at 1:38 PM
    And then it gets discontinued completely LOL.
  4. Jun 1, 2023 at 4:51 PM
    The 4Runner? Or, the Tacoma? I doubt either one is getting discontinued anytime soon.
  5. Jun 1, 2023 at 5:03 PM
    The 4Runner. I'm just giving shit to all the guys that keep their hopes up year after year.
  6. Jun 1, 2023 at 5:23 PM
    Ha! I remember when I started looking in 2018, thinking that maybe I'd wait for the 6th gen. Lol!
    But, now it seems pretty well established that the 6th gen is on its way next year... sometime... maybe...
    Whether or not it will be any good is unknown. Based on the new Taco, I'm pretty optimistic.
    :notsure:
  7. Jun 1, 2023 at 8:35 PM
    4R777
    New Tundra in 2022
    New Sequoia in 2023
    New Tacoma in 2023
    New Land Cruiser in 2023
    New 4runner in 2024
    Zerny and Thatbassguy like this.
  8. Jun 2, 2023 at 3:46 AM
    Gamma Ray
    2020 SR5 Barcelona Red
    You dillhole.
  9. Jun 4, 2023 at 9:49 AM
    TexasFunRunner
    TexasFunRunner New Member
    DFW
    SUV
    I absolutely hope you are correct, that is why I'm keeping a close eye on purchasing the 6th gen 4Runner or new Land Cruiser. But remember, CALTY is the stylistic design studio, not the detailed engineering groups responsible for the design of the drivetrain, electronics, etc.
    A slick marketing campaign does not equal solid engineering design or quality manufacturing. After seeing the Sequoia first year issues and the Bronco fiascos, I'm cautiously optimistic that Toyota learned from both and we will be pleasantly surprised with the new Tacoma, 4Runner and Land Cruiser.
  10. Jun 4, 2023 at 10:21 AM
    4R777
    A good point. But given Toyota's track record for reliability, the engineering part doesn't have me concerned. I think they'll get it right.
  11. Jun 4, 2023 at 10:48 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    I think they'll get it right too...
    but did they get the tundra grille right, it's massive and kinda gaudy
    but did they get the tundra tail lights right lol no
    the Tacoma tail lights are nearly the same level of ugly
    and could argue the Sequoia / Tundra headlights have too much going on, that's alot of led and wrap around.
    :D
    Thatbassguy and 2Toys like this.
  12. Jun 4, 2023 at 2:09 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    Roger that. The word I used was FUGLY.
    (Just my opinion...)
  13. Jun 4, 2023 at 4:11 PM
    Hahah ya, I've said before too that less is more. And I miss the old tight body's, trucks have all ballooned so big in our market.
    Just my opinion as well. Of course the features I referenced are just cosmetic, and are creative new designs that incorporate the safety requirements. I'm confident new Toyota powertrain and mechanical will still be solid.
