Torque specs for bumper bolt nuts.
Discussion in '4th Gen 4Runners (2003-2009)' started by McGG4, Aug 15, 2024.
  1. Aug 15, 2024 at 5:25 PM
    McGG4
    McGG4 [OP] New Member
    CRS
    2003 4Runner SR5 4WD
    Total - almost -replacement of every light bulb with LED's
    Does anyone know the torque specs for the bumper bolt nuts for '03 4Runner? I'm attaching bull bar brackets.
  2. Aug 15, 2024 at 8:05 PM
    4R777
    4R777 New Member
    PDFs from the Toyota Manual for removing and installing front and rear bumpers, as well as installing the Sport Bumper Trim.
    Try 064000.pdf for torque specs on front bumper.
    Try T-AI-0133-W for torque specs on bull par installation.
  3. Aug 15, 2024 at 8:24 PM
    McGG4
    CRS
    Hi, not sure we're talking about the same thing. Here's what came with the bull bar feel free to correct me if I'm wrong. If the attachments don't make it let me know and I'll resend them.
  4. Aug 16, 2024 at 3:49 PM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    I have the factory manuals if you do not find what you need.
  5. Aug 17, 2024 at 10:28 AM
    McGG4
    CRS
    That would be good because these nuts just will not loosen and I'm seeing vids on youtube where they're using standard wrenches with only one guy that said you're going to need a torque wrench to get 'em loose.
  6. Aug 17, 2024 at 10:57 AM
    Oakboro, N.C
    Please do not loosen anything with a torque wrench, You stand a huge chance of damaging it. Impact OK to loosen, No torque wrench.
    McGG4[OP] likes this.
  7. Aug 17, 2024 at 11:14 AM
    BLKNBLU
    BLKNBLU New Member
    2019 TRD OR Nauti Blue
    Agreed. What OP needs is a breaker bar.
  8. Aug 17, 2024 at 11:22 AM
    BLKNBLU
    BLKNBLU New Member
    OP, from your title I presumed you were trying to re-attach, not remove. Please keep in mind on an '03 those bolts may have never been moved in 21 years. Depending on your location rust and/or corrosion could be a factor. You may need a lot of leverage to get those loose.
  9. Aug 17, 2024 at 11:37 AM
    4R777
    4R777 New Member
    Pb Blaster + Breaker bar
    in that order
  10. Aug 17, 2024 at 1:54 PM
    McGG4
    CRS
    To RunHamRunner 7 Yes, I read up on it and didn't attempt it thank you. To BLKNBLU, that thought occured to me this morning since most vids showed much more current models thank you Now I just have to educate myself on what is a Pb Blaster and a Breaker bar.
  11. Aug 17, 2024 at 2:02 PM
    McGG4
    CRS
    In terms of length of breaker bar what would you suggest?
  12. Aug 17, 2024 at 2:12 PM
    You sure he didn't say impact wrench (gun)?
    McGG4[QUOTED][OP] likes this.
  13. Aug 17, 2024 at 2:21 PM
    McGG4
    CRS
    Actually he said breaker bar, don't know how I missed that and thank you for bringing it up.
  14. Aug 17, 2024 at 3:46 PM
    18" breaker bar should work. A length of steel pipe helps if you can't get enough leverage. If there's enough room for it to be used.
  15. Aug 17, 2024 at 11:17 PM
    McGG4
    CRS
    Ok, thanks all.
  16. Aug 24, 2024 at 7:36 PM
    McGG4
    CRS
    That's why I asked, a 24" would've been way too long the 18" was fine and thanks for the suggestion it was exactly the tool I needed.
    RonT4R likes this.
