Too much frame rust?
Discussion in '5th Gen 4Runners (2010-2024)' started by jpn, Mar 31, 2024.
  1. Mar 31, 2024 at 8:18 PM
    jpn
    jpn [OP] New Member
    433454548_919656236316760_2637227635549391572_n.jpg 433788157_832769775342841_4442150562041039086_n.jpg 433401559_1184552645848016_7530007949430401617_n.jpg 434070029_451704860542962_6507735045695226706_n.jpg 433621767_775421481220609_8320581960354706259_n.jpg 433584373_2495427943975594_3607526899785655102_n.jpg 433660183_952042856302004_4595634666635628253_n.jpg 433243066_465525492466336_8234826002261464513_n.jpg 433454548_919656236316760_2637227635549391572_n.jpg
    I am thinking about buying a 2010 4Runner Limited with 180,000 miles. It is in Illinois and I am wondering if this is too much rust and I should walk away? It seemed to drive fine, but I know this is a common issue, just not sure how bad it is. Any help would be greatly appreciated.
  2. Mar 31, 2024 at 8:27 PM
    Oakboro, N.C
    Welcome to the forum first off!
    Those pictures do not, in my opinion, look all that terrible based off of being g 14 years old. How do the other major systems of the vehicle look?
    Harringbr99, Ironguy and icebear like this.
  3. Mar 31, 2024 at 8:41 PM
    what you have pictured there is not absolutely horrible, however, the front body mount weldment should be carefully looked over, especially on the passenger side where the ac drains water. There should be some drain holes there, but they shouldn’t be big. You have to look at them from straight underneath to see the area well. Also look at tthe LCA frame mount area.
    In any case, resist paying top dollar just because it’s a “reliable” toyota. The value proposition gets dicey with any vehicle is this old. There’ll probabaly be some heavy maintanance due on it, at best. Make sure the frame is worth the work that will need to go into it.
  4. Mar 31, 2024 at 9:06 PM
    steelevo
    Utah
    Welcome.
    That just looks like a neglected undercarriage that has not seen regular cleaning. A lot is going to depend on the price, maintenance history, drive train condition, accident history, etc. Make sure to have a reputable independent mechanic do a full pre-purchase inspection. And don't cheap out on not doing the compression test.
  5. Mar 31, 2024 at 9:16 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    The rust that are pictured looks manageable.
  6. Mar 31, 2024 at 10:21 PM
  7. Apr 1, 2024 at 3:29 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Not a expert on rust.
    But you would have a tough time reselling or trading off down the line.
  8. Apr 1, 2024 at 5:19 AM
    kevinRR
    kevinRR New Member
    Wisconsin
    2022 Toyota 4Runner
    stock
    It's not bad for a 14 years old car in the midwest. If I was you I would take my time and find one that's from down south or out west.
    Slopemaster likes this.
  9. Apr 1, 2024 at 7:16 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Pass as well. There are so many out there in better shape. You're going to spend time and money chasing the rust on that one to achieve another 180K.
  10. Apr 1, 2024 at 7:30 AM
    Just noticed the big chunks inside the passanger side frame rail, covering some drain holes. That’s a fair amount of material that would have me concerned. I bet it came from just behind the body mount area drain hole.
  11. Apr 1, 2024 at 7:41 AM
    Sin4R
    Sin4R New Member
    2024 Underground Limited
    Mall crawling kit.
    I agree. This isn't unusual for 6-8 year old truck that lived in a rust belt. It will continue getting worse until it becomes a structural issue. It does not appears to be quite there yet.
    If this is your truck, start doing oil spray treatments. Use oil-based treatment like Krown.
    If you are looking to buy, pass on this one and look for one that has less rust. You can't undo existing damage easily and this one looks like half used up.
  12. Apr 1, 2024 at 7:41 AM
    Ironguy New Member
    I don't see terminal damage but I do see a bunch of work to remove what is there and follow-up for prevention.
  13. Apr 1, 2024 at 8:11 AM
    3JOH22A Toyota Gigolo
    It's a 14 year-old vehicle. @jpn should expect to drive it into the ground if he buys it.
    McSpazatron likes this.
  14. Apr 1, 2024 at 9:00 AM
    jpn
    jpn [OP] New Member
    Thank you all for your responses. After reading your posts I have decided to pass on this one and look for one with lower miles and less rust. I am now more determined to find a nicer one and I am so glad I joined this group! I believe you may have saved me a lot of money and trouble trying to iron out the rust issues.
    steelevo and Slopemaster like this.
  15. Apr 1, 2024 at 9:04 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    If it's 30% under market and all maintenance has been done, yes. Otherwise, no.
    steelevo and McSpazatron like this.
  16. Apr 1, 2024 at 9:20 AM
    jgalt
    jgalt New Member
    Fine to drive, not fun to work on.
    steelevo and kevinRR like this.
  17. Apr 1, 2024 at 10:01 AM
    Manhattan
    Manhattan New Member
    @jgalt nailed it. Repairs and maintenance work can end up costing lots more money or lots more bloody knuckles. Working on rusty trucks sucks.
    The "too much rust?" threads come up a lot on the older Land Cruiser forums. There's a difference. Land Cruisers are rare. 4Ru (there goes one) nn (there goes two more) ers are everywhere. Best case: Recheck AutoTrader in a couple hours for new listings. Worst case: Head south and make a roadtrip home in a 100% rust-free truck.
  18. Apr 1, 2024 at 10:18 AM
    TheGreekFreak
    TheGreekFreak New Member
    It's not ready for the junkyard yet but I would pass on this one. My 23yo 3rd gen spent its whole life in the northeast, driven daily, with a previous owner who was not as obsessive about maintenance as I am......and the undercarriage/frame have less rust than this.
    Rust is the absolute worst and can cause alot of issues to pop up that are not showing now. Like I did with my 3rd gen, I would take one with a few problems I can fix with replaced parts over one that seems good but is rusty. This coming from someone in Boston where everyone's undercarriage looks like the titanic.
    steelevo and jgalt like this.
  19. Apr 1, 2024 at 8:46 PM
    Probably a good call. I started out considering a used 12-14 year old 4runners, but around here the rust is just a nasty reality. Unfortunately, the prices people were asking for these rotten 4runners was stupid. I ended up putting off a purchase until it made sense for me to buy new.
    steelevo likes this.
