Too hot for fire extinguisher?
Discussion in 'Off-Roading & Trails' started by backpacker, Aug 27, 2023.
  1. Aug 27, 2023 at 8:17 PM
    backpacker
    backpacker [OP] New Member
    2023 TRD ORP
    It appears the most readily available fire extinguishers have a rated maximum storage temperature of 120F. I hadn't noticed this before, but it's clearly much less than a closed vehicle might experience in hot weather.
    Are there extinguishers with higher ratings?
    Do people just not worry about how much hotter the interior might get?
  2. Aug 27, 2023 at 8:47 PM
    Maybe these will work for you.
  3. Aug 29, 2023 at 8:43 AM
    backpacker
    2023 TRD ORP
    Thanks, that's interesting. I like how compact it is.
  4. Aug 29, 2023 at 9:00 AM
    BLKNSLVR
    BLKNSLVR New Member
    Shaine
    23 TRD OR 4Runner
    I've carried a fire extinguisher in my work van for years, had one in my tacoma and one in my current vehicle. To be honest It never crossed my mind about the heat and it not being able to withstand it.
  5. Oct 6, 2023 at 7:37 AM
    3JOH22A Toyota Gigolo
    According to Kidde, the discharge time may be reduced at higher temperatures: https://www.kidde.com/home-safety/e...cles/articles/storing-fire-extinguishers.html This is probably why the labels on my two Kidde extinguishers specify -40F to 120F as the "intended use" range:
    The cylinder and valve are tested to much higher temperatures and pressures in UL testing, so the extinguisher will not rupture in the vehicle interior due to heat. This particular Kidde model I bought from Home Depot is filled to 100 psi, but is tested to 300 psi according to the label. Just make sure your mounting bracket doesn't have damaging features like a screw head digging into the cylinder wall.
    You'll need 2-3 E100 sticks at a cost of $250-360 to equal the performance of a single 2.5lb extinguisher. Plus you need to be uncomfortably close to the fire to use it: https://www.4runners.com/posts/429058 Though it's better than having no extinguisher at all (e.g. you're backpacking on foot).
    Ripper238 likes this.
  6. Oct 6, 2023 at 7:45 AM
    I kept one in my Tacoma also for the entire time I owned it. It was stored in the cubby behind the drivers-side rear passenger seat. I plan on mounting the same one to a molle panel in my new 4 Runner.
  7. Oct 6, 2023 at 8:09 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    Car temp is not an issue, but it will effect the fire extinguishers performance.
    Always had to have a UL listed fire extinguisher in my commercial vehicles (FMCSA requirement) and the trucks didn't even have AC. Just think about it, all commercial vehicles are required to have a fire extinguisher, how many have been reported to blow up?
    3JOH22A likes this.
  8. Oct 6, 2023 at 10:22 AM
    backpacker
    2023 TRD ORP
    Yes, it seems uncommon anecdotally. Although I can't find it now, there's at least one report on the forum of a fire extinguisher that released contents while unattended. It's good to know that the temp specs are about performance rather than containment failure.
  9. Oct 6, 2023 at 10:32 AM
    Ripper238
    2019 TRD OR
    If i recall there was one that was not UL listed in another country that discharged.
  10. Oct 6, 2023 at 10:45 AM
    kojak
    kojak New Member
    21 SR5P 4x4
    The FESA5 fits in door cup/bottle holders and after a few years of baking the pressure checker still reads good. Once I grab a couple replacements I'll do a hot test discharge, for science.
  11. Oct 6, 2023 at 1:34 PM
    Ripper238
    2019 TRD OR
    Make sure to take video and post!
  12. Feb 9, 2024 at 1:46 AM
    electricryano
    electricryano New Member
    Ryan
    2012 Toyota 4Runner Trail with KDSS
    33” Maxxis Razr DIY Prisnu roof rack 18” Bumper LED
    Hey 3JOH22A,
    I hope you’re right for most folks. But a few years ago I was driving through town for work, about 2 pm. 4R had been sitting in the sun all morning. The extinguisher I had mounted on a Molle panel in the back window just started unloading randomly. I had no idea what was happening at first but rolled all the windows down and pulled over. Everyone probably thought cheech and Chong went nuts the way my truck was smoking. Smells weirdly like burnt chemicals. Cleaning up was a chore. I’m not keeping one in my truck over the summer anymore.
