To engine swap or not to engine swap
Discussion in '2nd Gen 4Runners (1990-1995)' started by Guttiirunner, Apr 24, 2017.
  1. Apr 24, 2017 at 3:32 PM
    Guttiirunner
    Guttiirunner [OP] New Member
    Castroville
    90 4runner 4x4
    Recently purchased my 4runner and it seems like it might need a headgasket change, i dont want to encounter any more problems if i take apart the engine. It has about 182000ml would it be better if i swapped the engine out for something better? Is there a certain engine that would be easy to swap and/or any better than the stock engine??
  2. Apr 26, 2017 at 11:38 AM
    bahndrvr
    bahndrvr New Member
    Trevor
    Melbourne, Fl
    03 SR5 V8 4Runner
    2003 4Runner SR5 v8 - Temp Front: Top hat spacer 2.5" on Tacoma struts/springs Rear: TJM/King heavy extended Tacoma shocks 315 BFG AT KO2's (35's) Thrush Welded muffler and rear watermelon delete with turned exit K&N drop in, and extra filter delete Strengthened/Welded passenger side front diff mount Front diff drop - due to the top hat spacer and massive droop.... Scion headunit CB Other stuff done, 6th 4Runner:)
    Search is your friend, but the 3.4 is a relatively easy - as far as engine swaps go - and would give you a lot more power, better mpg, and is just overall better.
    Guttiirunner[OP] likes this.
  3. Apr 29, 2017 at 10:08 AM
    Guttiirunner
    Castroville
    90 4runner 4x4
    Thank you for the suggestion i will look more into it.
