Tnuts and Bolts
Discussion in '5th Gen 4Runners (2010-2024)' started by Shnook718, Sep 4, 2024.
  1. Sep 4, 2024 at 12:27 PM
    Shnook718
    Shnook718 [OP] New Member
    shaun
    4runner
    Any recommendations on type of Tnuts and bolts for your Prinsu roof racks?
  2. Sep 4, 2024 at 1:56 PM
    RUNNER4DAN
    Daniel
    Doesn't need any
  3. Sep 4, 2024 at 2:54 PM
    I think the inferred preferred fastener for the Prinsu extrusions is a common carriage bolt.
  4. Sep 4, 2024 at 3:07 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
  5. Sep 4, 2024 at 3:49 PM
    I love the high-speed-low-drag stuff from McMaster. I recommended carriage bolts because the Prinsu rack has round holes at the ends of the crossbars.
  6. Sep 4, 2024 at 3:58 PM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    Captain Spalding likes this.
  7. Sep 5, 2024 at 9:36 AM
    Shnook718
    shaun
    4runner
    what size do you recommend?
  8. Sep 5, 2024 at 9:50 AM
    Sorry I don’t have a Prinsu rack. But it’s a simple matter to determine the size. First measure the width of the slots and the hole at the end and then go to your local hardware store and measure some carriage bolts. Pick the largest size that will fit, while allowing the square lug on the shank of the bolt to slide easily in the slot but not spin. The length of the bolt will be determined by what it is that you are bolting to the rack.
  9. Sep 5, 2024 at 10:03 AM
    Shnook718
    shaun
    4runner
    I measured and concluded an M5 or (1/4in) carriage bolt would fit. I just want to make sure that's what everyone else is using. I also considered the roll in Tnut with ball spring.The reason I ask is because I'm mounting a water port and I have never mounted something that heavy to the roof with a small footprint. I'm using the Rago Fabrications mount. I just want to ensure that this thing doesn't fly off and hit someone and cause an accident. This will be the first thing I have ever mounted to my new Prinsu Pro roofrack.
  10. Sep 5, 2024 at 10:13 AM
    You might want to go the extra mile and find rated fasteners. Grade 5 is fine. (Or 8.8 if you’re using metric.) I suspect rated carriage bolts are a bit of a specialty item not available at the neighborhood Ace. McMaster has them. They have minimums though.
    backpacker likes this.
  11. Sep 5, 2024 at 2:36 PM
    wingo
    wingo *****
    2020 Venture
