Tires rub
Discussion in '5th Gen 4Runners (2010-2024)' started by tblt44, Mar 5, 2023.
  1. Mar 5, 2023 at 2:34 PM
    tblt44
    tblt44 [OP] New Member
    Todd
    Tampa
    2021 4 runner
    N/A
    New wheel/tires rub.
    I figure they might.
    17x8.5 method wheels with 265/70R17 wildpeaks.
    Will do trimming soon but now thinking level or lift kit 1 to 2 inches.
    Don't want it high just no rub off road.
    Any suggestions?
    Dabigono likes this.
  2. Mar 5, 2023 at 2:43 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    if it’s rubbing when backing up at full lock, I would recommend doing the front bumper trim & fender liner mod first.
    Great looking rim & tire combo
  3. Mar 5, 2023 at 3:26 PM
    Agent_Outside
    Built 2011 T4R Limited
    If it rubs now you need to fix there it rubs. A lift won't make that not rub offroad.
  4. Mar 5, 2023 at 3:28 PM
    Trees91
    Trees91 New Member
    Forrest
    South Dakota
    2023 MGM SR5p
    0 offset? Just curious...I have 17x8.5 wheels waiting for tires.
  5. Mar 5, 2023 at 5:22 PM
    tblt44
    Todd
    Tampa
    2021 4 runner
    N/A
    Yes zero offset and rub in reverse turning
  6. Mar 5, 2023 at 5:48 PM
    You're most likely rubbing on your mudflap right now. You could try remolding the mudflap a little with a heat gun, although that doesn't usually make a huge difference. You could also remove the front mudflaps.
    If you don't want to remove the mudflaps, your best bet is an alignment and the fender liner mod.
    Ask the alignment tech to push the caster forward as far as reasonably possible (probably around 3.8 degrees or so). This puts your wheel further forward in your wheel well slightly. Just enough to get away from your mudflap.
    With that much caster, you'll then need to do the fender liner mod because you might be rubbing on the fender liner/fender flare in the front of your wheel.
    After that you should be good to go.
    SlvrSlug likes this.
  7. Mar 5, 2023 at 6:48 PM
    That’s interesting that you’re having rubbing with stock size tires?
  8. Mar 5, 2023 at 8:28 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Crank your steering wheel all the way to one side. Follow the tires straight up in front and back and see if they will hit when articulated.
    Crank the steering wheel all the way to the other side. Again. Imagine a line straight up and see if the time will hit anything if it articulates up.
    Or. Look at your plastic and see what has rub marks.
    Since those are small tired you should be able to have an alignment shop push them slightly away fro. Where they are rubbing.
    However the fact that they are rubbing when not articulating is alarming and you may need to cut a little bumper. Or remove mud flaps.
  9. Mar 5, 2023 at 9:02 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    like everyone is saying. it’s a matter of addressing the point of rubbing.
    i’m have 265 wildpeaks on SEMAs. i rubbed slightly in reverse locked either way stock height and really rubbed after lifting the truck. the rub was the front bumper cover.
    no rubbing off road either way though.
    nimby likes this.
  10. Mar 5, 2023 at 9:58 PM
    Icetenka
    Icetenka New Member
    2023 TRD ORP
    I’m running as well when reversing and cracking the wheel to fill articulation. Haven’t done the front bumper trim & fender liner mod yet. Also going to try to take a heat gun to the mud flaps or cut the area it’s rubbing before adjusting the castor.
