Tires and leveling kit
Discussion in 'Wheels & Tires' started by Grey goose, Feb 15, 2024.
  1. Feb 15, 2024 at 12:19 PM
    Grey goose
    Grey goose [OP] New Member
    Brittany
    2022 4 runner limited 4wd
    I need help. I’m planning on putting a leveling kit on my 2022 4Runner limited 4wd. Will 285/60/20 Toyo open country tires fit with just a leveling kit?
  2. May 15, 2024 at 8:51 AM
    CC-2224
    CC-2224 New Member
    2021 4runner Limited
    I am doing the same thing to my 4Runner limited 2021. Be sure that your leveling kit fits Xreas system. Also you may need to push your fenders back.
  3. May 15, 2024 at 8:56 AM
    Oakboro, N.C
    CC-2224 likes this.
  4. May 15, 2024 at 8:56 AM
    CC-2224
    CC-2224 New Member
    I am doing the same thing to my 4Runner limited 2021. Be sure that your leveling kit fits Xreas system. Also you may need to push your fender. I’m not 100 percent sure but I do believe you will need smaller rims, to fit 285s. I am buying 17inch wheels to fit 285s. The stock rims are 20inch on a limited.
  5. May 15, 2024 at 10:34 AM
    Grey goose
    Brittany
    2022 Toyota 4-runner limited 4wd with xreas system. Installed 3in Corn Fed leveling kit with 285/60/20 Toyo open country mt. Pushed front fender up a little and removed the smaller part of the mudd flap on the backside of the front fenders no scrubbing at all
    Klinsman55, hossler1788 and CC-2224 like this.
  6. May 15, 2024 at 12:19 PM
    2016Pro
  7. May 15, 2024 at 1:05 PM
    CC-2224
    CC-2224 New Member
    What leveling kit did you purchase?
  8. May 15, 2024 at 1:43 PM
    Grey goose
    Brittany
    Corn fed
  9. May 15, 2024 at 2:18 PM
    If you have a 4wd, you are not going to lift it high enough without requiring a diff drop down bracket
    If you have a 2wd you can lift it higher without worry
    You are going to need AT MINIMUM 2.5" of lift up front and the fenders pushed forward and remove the mud flaps or you are going to rub like hell
    If you have a 4wd with Xreas, pretty much 1.5" is as high as you can go without a diff drop down bracket
    If you pull the Xreas off you can put SR5 shocks or aftermarket shocks on and do a 2.5" lift up front with diff drop down bracket
    You can run a 2" up front and fit a 275/55-20 or a 285/55-20 with moving inner fender forward and removing mud flaps
    You can run a 2.5" up front and fit a 305/50-20 with moving the inner fender forward and removing the mud flaps
    If you have a 4wd you are going to rub like hell with a 285/60-20 even with removing the mud flaps, you simply cant get the front high enough due to the front diff.
    If you have a 2wd you can lift it higher but you are still going to rub like hell cause thats a big tire. Thats a 33.5 x 11.2, the first problem is rubbing the A-arm the second is the inner fender against the front bumper, the third is the inner fender where the mud flap mounts, the fourth is the body mount.
    I would suggest one of the other 3 sizes i listed which will all fit much more better.
