Tire Repair Kits: What has worked for you?
Discussion in '5th Gen 4Runners (2010-2024)' started by TDRProDave, Jan 16, 2022.
  1. Jan 16, 2022 at 9:38 AM
    TDRProDave
    TDRProDave [OP] Here for the gear
    David
    South Bay
    2018 Cavalry Blue TRD Pro
    Kumho AT51 tires, OEM Rock Rails, Talons Garage CC Cover
    I was offroading yesterday and thought briefly about how much if would suck to have to replace a tire on a cold, windy ascent. Fortunately, there were no issues at all. But it did make me think about what would be the best tool for fixing a leak/flat if I needed to do so. Does anyone have experience with a kit that has worked well for them?
  2. Jan 16, 2022 at 1:02 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
  3. Jan 16, 2022 at 1:04 PM
    heyniko24
    heyniko24 New Member
    Niko
    21 Venture
    The one we use at the shop is safety seal brand and the handles are heavy helps you get the job done fast
    Toy4X4, photo8 and TDRProDave[OP] like this.
  4. Jan 16, 2022 at 1:43 PM
    TDRProDave
    David
    South Bay
  5. Jan 16, 2022 at 1:46 PM
    TDRProDave
    David
    South Bay
    Thanks! In your experience do you replace the tire valves at all or do the valves rarely if ever fail/break off? The reason I ask is that I am thinking about going with the Safety Seal product but wonder if I should also buy valve replacement kits or if that is not something that is likely to be a problem.
  6. Jan 16, 2022 at 1:49 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    TDRProDave[OP] likes this.
  7. Jan 16, 2022 at 1:58 PM
    heyniko24
    Niko
    21 Venture
    are you talking about the inner core valve ?
    if your off-roading and deflating pressures and inflating a lot the inner core valve had a seal that gets worn always good to have replacements . But the rubber that the valve sits in requires you to break the bead to replace
  8. Jan 16, 2022 at 2:04 PM
    Had a flat in the garage with the sequoia (slow leak) a nail.
    The tread was to worn for tire shop to patch, but I decided to practice plugging the hole with the repair kit.
    It’s not as easy as I thought it would be. Took three attempts and different plugs to get the rubber rope to insert properly. I nearly broke the plastic/metal tool.
    I suggest you get the kit with the all metal handle design and practice on an old tire.
    I had the tire/wheel removed from vehicle and spare on. It was still difficult with a straight leverage angle getting the patch/plug in.
    Once I did get the plug in it held air just fine. I suspect it would have been more difficult plugging the hole with the tire/wheel still installed on the vehicle.
    Toy4X4, K-Paul and TDRProDave[OP] like this.
  9. Jan 16, 2022 at 2:09 PM
    Dabigono
    2020 4Runner
    It doesn’t, it’s just for inflating my tires. I use this to air down…
    ARB ARB600 E-Z Deflator with Bar/Psi Gauge Include Recovery Gear Bag
    by Trends Auto
    Learn more: https://www.amazon.com/dp/B004P9DQHQ
  10. Jan 16, 2022 at 2:14 PM
    TDRProDave
    David
    South Bay
    Got it, thanks again.
  11. Jan 16, 2022 at 2:16 PM
    TDRProDave
    David
    South Bay
    This is good info. I think I am going to go with one of the more heavy duty kits that is all metal like you suggest. Hopefully I never need to use it but with kids I would be super annoyed if the tool busted while using it in a real life situation.
  12. Jan 16, 2022 at 2:20 PM
    That sounds like a good plan. If and when I set out on a long road trip, I would probably replace my cheap kit with a better one.
  13. Jan 16, 2022 at 2:41 PM
    OverRunner
    OverRunner rebmeM weN
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    This is what I did. My long-term goal is to get the ARB twin, but I have a nice Northern Tool cheap alternative for now, that I plan on handing down to any one of many buddies who don’t have anything at the moment.
  14. Jan 16, 2022 at 3:32 PM
    Mass4runner
    Mass4runner New Member
    2023 TRD ORP
    I have the safety seal kit. Only used it once but it worked like a charm. It's a bit pricier than the others but it's supposed to be higher quality.
    heyniko24, JaSC and TDRProDave[OP] like this.
  15. Jan 16, 2022 at 3:47 PM
    TDRProDave
    David
    South Bay
    Yeah, I am pretty sure that is the route I will go. The guy who said they use it in his garage really sold me. For something like a leaky tire I don't want to be caught with a repair kit that won't work. No bueno.
    JaSC and Mass4runner[QUOTED] like this.
  16. Jan 16, 2022 at 4:05 PM
    Mass4runner
    2023 TRD ORP
    That was my thinking. For an extra $25 the peace of mind is worth it to me.
    TDRProDave[QUOTED][OP] and JaSC like this.
  17. Jan 18, 2022 at 6:24 PM
    Good recommendations here. Anyone have a preferred link for the safety seal kit?
    Also, I never knew I needed a 300 dollar bottle jack kit….sigh
    Dabigono likes this.
  18. Jan 18, 2022 at 6:28 PM
    Dabigono
    2020 4Runner
    got it for cheap on OFFER UP. used, but cheap
  19. Jan 18, 2022 at 6:54 PM
    As was mentioned, you would have to dismount the tire in order to replace the valve with a rubber one, they pop in from the back. I found this a few months ago, I now keep it in my 4Runner with the tire repair stuff. These are emergency valves, you can insert them in the wheel from the outside. If you have TPMIS the sensor will rattle around inside the wheel until you can get it properly fixed, but it will get you off the trail and home.
    Colby Valve Emergency Valve Stem Replacement (Black) https://www.amazon.com/dp/B01NARX3H8
    I also carry the whyskey tire repair kit from AMZ, which seems to be very high quality and similar to the safety seal, just comes with a few more accessories and pieces. I took it out of the plastic case and put it in a nylon molle pouch to save space. I also have the maxi track air compressor from Napa, it's a twin cylinder beast, and with AAA discount it was $104. Haven't tried it on my 4Runner yet, but it pumped up the tire on my Volvo XC70 from near flat to 35 PSI in about 40 seconds.
    K-Paul, ElectroBoy, SlvrSlug and 2 others like this.
  20. Jan 19, 2022 at 7:59 AM
    TDRProDave
    David
    South Bay
    Thanks, I picked up the Colby valve replacements. Those look really good and have great reviews. How did you get the AAA discount on the Napa air compressor?
  21. Jan 19, 2022 at 4:16 PM
    I ordered the compressor and a few other things online, with pick up and pay at the store. When I got there and paid, they're good about asking about AAA, so he asked me and applied the discount. If they don't ask at your NAPA, I would ask for it. If you have AAA that is, haha.
  22. Jan 19, 2022 at 4:59 PM
    Beachguy
    2024 TRP ORP
  23. Jan 19, 2022 at 5:05 PM
    Those valves are super clever, huh? I was really impressed when I saw them, I had never heard of them till somebody in a group that I'm in mentioned them as being a good thing to add to the emergency kit. I bought them right away too, with the TPMS valves being hard mounted with no give, breaking or damaging is something that it really concerns me.
    This is the tire kit that I bought, btw:
    WYNNsky Heavy Duty Tire Repair Tools Kit - 54 Pcs Set Truck Tool Box for Motorcycle, ATV, Jeep, Truck, Tractor Flat Tire Plug Kit https://www.amazon.com/dp/B06X15JJ4F?_encoding=UTF8
    I ditched the case and put everything in Maxpedition pouch.
  24. Jan 19, 2022 at 5:44 PM
    K-Paul
    Corbin Dallas
    SR5 4WD
    Dude I have the same compressor, and it is indeed Orange Godzilla.
  25. Jan 19, 2022 at 6:11 PM
    K-Paul
    Corbin Dallas
    SR5 4WD
    One of the best suggestions I have seen here in awhile. Im getting new tires on my wife's Highlander and I was already planning on bringing a tire home to turn into a practice tire.
    The trail is certainly NOT the place you want to be performing this for the first time..... that said if you can get two or three under your belt, its the faster way to get back on the trail as opposed to doing a tire switch (In most cases anyway)
  26. Jan 19, 2022 at 9:18 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    I had an ARB kit.
    I’m sure they all come out of the same factory in China.
    Trail Runnah and K-Paul like this.
  27. Jan 20, 2022 at 3:24 AM
    I've used this plug kit to plug tires on a trailer ranging all the way to my quad-axle dump truck, the only time it did not work was a screw hole in the corner of a tire by tread face and sidewall on a car. So about 90% sucess rate. the "shrader valve" core rarely needs to be replaced, with the exception if you use a fix-a-flat sealant like Slime or etc. I have pretty good faith in the plug kits, but they are only a 'crutch' until you can get to a place to properly fix it.
  28. Jan 20, 2022 at 3:56 AM
    Beachguy
    2024 TRP ORP
    Haven’t had to use it yet, thankfully.
    A&P[QUOTED] likes this.
  29. Jan 20, 2022 at 3:30 PM
    MAXIM
    MAXIM New Member
    I found steady leak due to wire punched small hole on the tread. I used basic kit and it worked like a charm. It is as easy as it looks on multitude of videos. Buy any brand in any budget range as long as tools have T-handle design because you might have to use some force if your tires 6 ply or more.
    Toy4X4 likes this.
  30. Jan 21, 2022 at 6:49 AM
    DRobs
    DRobs New Member
    Dan
    Missouri Ozarks
    2019 TRD OR - MGM
    Posted this before but I have plugged 3 tires using this Wynnsky tire plug kit:
    https://www.amazon.com/gp/product/B06X15JJ4F/
    The lube is handy for getting the plugs into the tire. The pliers are handy for pulling nails out of tires. The kit comes with spare valve cores. I dumped everything into a canvas medical pouch and trash canned the box.
    For airing up tires, I've been really impressed by my Viair 300P. I use it on weekly off road trips. It is fast! Can go from 20psi to 40psi in a couple minutes per tire.
    https://www.amazon.com/gp/product/B000X90YUO/
    For airing down tires, I use this Viair Tool. It is basically the same tool that is on my Viair compressor w/o the long hose.
    https://www.amazon.com/VIAIR-00032-Air-Down-Gauge/dp/B000FPXS04/
    Review (not mine)
    https://www.youtube.com/watch?v=s5njFu4MTiw
    TDRProDave[OP] and suaveflooder like this.
