Tire Pressure Help - Mickey Thompson 285/70/17s
Discussion in '5th Gen 4Runners (2010-2024)' started by raimieb, Jan 3, 2024.
  1. Jan 3, 2024 at 1:23 PM
    raimieb
    raimieb [OP] Hobby Mechanic - Love Our 4Runner!
    raimie
    2021 ORP 4x4
    Lots…
    Gents, just got some new shoes today. Wondering what the correct on-road tire pressure for Mickey Thompson 285 70 R17s C load is?
    Grateful for you.
  2. Jan 3, 2024 at 1:35 PM
    35PSI
  3. Jan 3, 2024 at 2:01 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Which tire did you buy? I didn't know mickeys made 285s in c load?
  4. Jan 3, 2024 at 2:41 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    285/70R-17 MICKEY THOMPSON BAJA BOSS A/T SL - So SL Load which I thought was C load.
  5. Jan 3, 2024 at 2:41 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Thanks Loco!! :)
  6. Jan 3, 2024 at 3:01 PM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    You can get them in the 285 standard load. Only 4lbs difference between 265/70/17’s.
  7. Jan 3, 2024 at 3:51 PM
    Load C is a Light Truck tire rating, which generally need to be run at slightly higher pressures than standard load tires. I’m guessing, yours should be run closer to factory tire pressures.
  8. Jan 3, 2024 at 4:14 PM
    scanny
    scanny New Member
    Ontario, Canada
    from the manual:
    Check that the number given by dividing the maximum load by 1.10 of
    the replacement tire is greater than 1/2 of the Gross Axle Weight Ratings
    (GAWR) of either the front axle or the rear axle, whichever is greater.
    For the GAWR, see the CertificationLabel. For the maximum load of the
    tire, see the load limit at maximum coldtire inflation pressure
    correct pressure can be found in LT tires pressure table, I used Toyo tire table, but I guess it's the same for other LT tires:
    Tire Load Limits (lbs.) at Various Inflation Pressures (PSI) - LT285/70R17
    35 40 45 50 PSI
    2105 2315 2510 2755 Lbs
    So 35 psi should be enough, but I wouldn't go much lower for long highway driving since all tables never shows anything under 35psi for LT tires. Probably load capability drop is not linear and LT tires load is different from P-metric tires. When I had stock side LT C load tires I ran them on 36-38 psi, but it was for stock size and stock size has 1925 lbs on 35 psi my SR5 needed minimum 1719.5 lbs per tire.
    Y0TA and raimieb[OP] like this.
  9. Jan 3, 2024 at 5:26 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    35 it is! Appreciate y’all!
  10. Jan 3, 2024 at 6:15 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    Wait, I thought it was established they were SL loads, not an LT285 C load?
    I have rugged trek SL load 285/70s and the online tire pressure calculator said to run them at 26 PSI.
    They were filled to 38 when mounted but didn't touch the road about 1" from each edge, and also rode like rocks. I dropped to 28-30 and they ride much better and now wear all the way across. SL is basically the same as P load (stock) so the larger footprint requires less PSI for the same weight
    Or am I just driving around now on flabby tires? 28-32 looks and feels right
    raimieb[OP] likes this.
  11. Jan 3, 2024 at 6:30 PM
    scanny
    scanny New Member
    Ontario, Canada
    LT tires generally need more pressure
    ChessGuy likes this.
  12. Jan 3, 2024 at 6:33 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Mine seem to be not touching about the same 1 inch from the sides. They’re at 35 right now. Here’s the Mickey Thompson link.
    247502 is the model number. it says 44psi but at 35 it’s not touching on the edges. So I’m confused a bit.
    https://www.mickeythompsontires.com/light-truck-tires/baja-boss-a-t
  13. Jan 3, 2024 at 6:39 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    That chart is telling you what the maximum load is at maximum inflation of 44 psi. Maximum inflation is not the recommended inflation for your vehicle at standard load. That will be closer to your factory door sticker and possibly lower as mentioned earlier due to your tire size being wider than OEM which will distribute the same load across a larger surface area.
  14. Jan 3, 2024 at 6:55 PM
    Add some pictures....I want to see them. This is the next set I am thinking in getting.
    35psi is what I think most people run these things at. I have to be honest, I can't ever get straight all of this C, ST, LT, loads, rating,...blah..blah. So much lingo and terminology that I wonder if it is tactics to keeps us all confused.....because if you look at the ownership of these tire companies...they are owned by just a few of them with a bunch of rebranding names thereafter. Anyway, congrats on the set. Hope you tell us how they feel.
  15. Jan 3, 2024 at 7:00 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Thank you. That is helpful. I’ll upload some pics tomorrow;)
    5thToy[QUOTED] likes this.
  16. Jan 3, 2024 at 7:00 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Amen!
  17. Jan 3, 2024 at 7:05 PM
    smatson
    smatson New Member
    Scott
    2019 TRD PRO
    Westcott lift / Mickey Thompson Baja Boss AT’s / S&B CAI/ Sprint Booster / DDS3 Max PODS / TRD Exhaust
    Just switched from 285/70/17 KO2’s C-Rated to Mickey Thompson Baja Boss AT’s LT-Rated.
    Liked these tires so much I put them on both our 4Runners.
    Anyway, started at 42psi, dropped to 40psi, to 38psi and now settled on 35psi for both rigs.
    Needed to get to 35psi for a comfortable ride.
    djwantke likes this.
  18. Jan 3, 2024 at 7:07 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Tried this and it came up with 26PSI
    If anyone wants to help double check my work that would be amazing. Just want to do what’s right for these.
  19. Jan 3, 2024 at 7:09 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    @raimieb excellent tire choice my friend!
    I opted for big daddy LT load E this time. 285/70
    Tires say 80psi max haha:eek:
    My Baja ATZ's were replaced by MT with the Baja Boss
    I run 38psi now, I was at 36
    Door says 32psi for passenger 265's, so irrelevant
  20. Jan 3, 2024 at 7:11 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    I re read this about ten times. Now I see what you’re saying. Mine came up with 26PSI also on the calculator.
    thanks DJ! Actually, seeing your posts pushed me to get it done!! So funny you wrote because I thought of your rig today when getting them put on. Appreciate you. Yeah, I’ll try and fiddle with the psi in the morning as well as mudflap delete to avoid the rub. Then report back. Appreciate you brother!
    djwantke[QUOTED] likes this.
  21. Jan 3, 2024 at 7:14 PM
    38 if you go by the calculator on tiresize.com. I have Toyos in the same size and load range, and tend to run them at 35.
    Most folks will run lower pressure than what's recommended.
    SlvrSlug likes this.
  22. Jan 3, 2024 at 7:52 PM
    I agree with James, and the calculator thing. But if you go by the calculator, you would need to weigh the front and rear loaded and empty. Then also that needs to be adjusted for mods. Bumpers, winches, slider’s, and stuff. Then i have still noticed that my tires are not running full tread on the road, so to keep with the :deadhorse: i adjust the air accordingly, chalk test, dirt test or whatever, i want all the tread front and back on the pavement. Hey, I’m old, change is hard for me. Oh shit, i almost forgot to add, i do not sell tires for a living, and i like when mine are wearing even.
    raimieb[OP] and Thatbassguy like this.
  23. Jan 3, 2024 at 8:01 PM
    I know I'm always pushing the calculator, but I ran lower pressure in my KO2's, and it seemed to work out fine.
    I definitely agree that it makes more sense to go by the actual running weight of your vehicle than by GVWR.
  24. Jan 3, 2024 at 8:03 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    I need help with my KO2 Load E 285/75/R17s. Guys, help!
  25. Jan 3, 2024 at 8:23 PM
    Off topic, but how do you like these tires so far?
    I'm thinking of getting these in this size and SL for mine too. Personally I would start with 35 PSI.
  26. Jan 4, 2024 at 2:54 AM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Just on today. Need to adjust and retry. Going with chalk method today to test and will report back. I have them on my Toyota Sienna and they’re beasts, which I like.
  27. Jan 4, 2024 at 5:50 AM
    MusashiSushi
    MusashiSushi New Member
    Colorado Springs, CO
    2023 4Runner SR5 Premium Black/Black
    Elka 2.5 DC 3" lift, SPC UCA's, Toytech rear springs, ARB Diff Breather, RSG Rock Sliders & front Skid. C4 front bumper with High Clearance sides and Warn Winch.
    Been running mine at 35psi with no issues.
  28. Jan 4, 2024 at 6:00 AM
    You have these on a Sienna?? Badass! I need to see pics of that!
    djwantke and raimieb[QUOTED][OP] like this.
  29. Jan 4, 2024 at 6:00 AM
    RusPro17
    Don
    Pa.
    IMG_4615.jpg Been running my 265/70/17’s at 35 and ride nice and no road noise. Also great in the snow which I tested in about 5 inches a few weeks ago. I was planning at first not to go to 285’s but knowing they are only 4lbs difference I may switch them out down the road.
    MEski4x4, djwantke and Trail Runnah like this.
  30. Jan 4, 2024 at 7:27 AM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Same 285 size? If so you getting full contact on all edges?
