Tire pressure display
Discussion in '5th Gen 4Runners (2010-2024)' started by KTT, May 6, 2020.
  1. May 6, 2020 at 12:32 PM
    KTT
    KTT [OP] New Member
    2020 white 4Runner
    bought a new 2020 4Runner last october, with a set of good year off road tires with reams and tire sensors. all install by dear. was ok all winter. when replace off road tires with original tire. no tire pressure detected.dealer said need to be replogram. so....need to pay twice a year for replogpam...for a 6 month old new vehicle.can some body help.
  2. May 6, 2020 at 12:41 PM
    Mtbpsych
    Mtbpsych New Member
    I don’t see why you need to reprogram. I don’t know about 2020’s but just swapping the sensors should be all you need to do when changing your setup, so I would ask if they installed the original sensors in when swapping tires?
  3. May 6, 2020 at 12:54 PM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    I swapped sensors from limited wheels to TRD pro wheels and got new tires. No programming needed.
    ifaik, programming is only if your replacing with new sensors. But why when you have a perfectly working set.
  4. May 6, 2020 at 1:10 PM
    Big B
    Big B Out Exploring
    Reno/Tahoe
    2020 TRDOR
    KINGS! w/ adjust Method Race Wheels, Good Year Ultra-terrains 285/70/r17, GOBI Rack, Baja-Designs/Cali-Raised LED Lights, SSO stealth front bumper, RSG Sliders, FACTOR 55 ultrahook Smitty Bilt x20 winch (syn.), TYT TH9800, X Bull Recovery Boards
    mine showed blank for half a day or so, then started working
  5. May 6, 2020 at 2:27 PM
    KTT
    KTT [OP] New Member
    2020 white 4Runner
    when replace the origginal tire with off road tire last october. it takes 2 days to show tire pressure. replace off road tire back to original tires 5 weeks ago. still will not show tire pressure..
  6. May 6, 2020 at 2:32 PM
    Are you using the same set of wheels and just swapping tires?
    Or, do both sets of wheels have sensors in them?
  7. May 6, 2020 at 2:39 PM
    KTT
    KTT [OP] New Member
    2020 white 4Runner
    both sets with sensors. from dealer.
  8. May 6, 2020 at 2:54 PM
    Sounds to me hes grumbling about having to pay the dealer to reprogram the sensors when he swaps rims and tires back and forth.
    Which sounds normal to me as it doesn't sound like hes swapping the sensors.
    As far as I know the 4R doesn't remember old sensors once new ones are programmed.
  9. May 6, 2020 at 2:59 PM
    KTT
    KTT [OP] New Member
    2020 white 4Runner
    2 set of tires with their own ream and sensors/ one for sumer and one for winter.
  10. May 6, 2020 at 3:03 PM
    KTT
    KTT [OP] New Member
    2020 white 4Runner
    both set of wheels with senors inside. install by dealer.
  11. May 6, 2020 at 5:16 PM
    Mtbpsych
    Mtbpsych New Member
    If you’re swapping out different sensors, although OEM, yes you WILL have to pay. Your truck can only recognize one set. To avoid that you have to KEEP one set on sensors in play at all times. Otherwise you will pay each time you put the other set of sensors on. Our trucks aren’t super computers lol.
    KTT[QUOTED][OP] likes this.
  12. May 6, 2020 at 5:22 PM
    Daytonaviolet
    Bay Area, CA
    if i understand this correctly, you have two set's of wheels/tires/sensors ? if so, the 4runner can only remember 5 sensors at a time. if you swap, you''ll need to program again. another option is to use use techstream to program yourself :)
  13. May 6, 2020 at 6:00 PM
    KTT
    KTT [OP] New Member
    2020 white 4Runner
    Thanks for the info.
    7385 likes this.
  14. May 6, 2020 at 7:11 PM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    Just had my SCS wheels added with new tires. My tire shop aired down my Pro wheels and removed monitors and added standard valve stems to my stock pro wheels and tires. And added the monitors to my new wheels and tires. Make sure they go where they came off. No issues detecting the monitors.
    Daytonaviolet likes this.
