Tire Help!
Discussion in '5th Gen 4Runners (2010-2024)' started by Icculus89, Jul 2, 2024.
  1. Jul 2, 2024 at 9:31 AM
    Icculus89
    Icculus89 [OP] New Member
    Michael
    TN
    2021 Metallic Grey SR5 Premium
    I'm a noob when it comes to this kind of stuff but I'm trying to learn haha...
    I just purchased a 2021 SR5 Premium that came with Ironman RB-SUV tires 265/70/17.
    They are smooth tires and drive great but I want to upgrade with bulkier, wider tires that mimic the TRD Pro stock tires and fill in the gap in the wheel a bit.
    Does anybody know the largest tire (I'm thinking BF Goodrich All-Terrain T/As) that I can put on the truck without having to lift it?
    Will an all-terrain tire at 265/70/17 look good? Or do I need to buy new tires AND wheels to give it that look I want?
  2. Jul 2, 2024 at 9:39 AM
    wax poetic
    wax poetic Raking like a mofo
    21 Super White TRD OR
    It will look better and be less expensive if you go with the oem size and an at tire (Toyo/Falken/BFG/Nitto) If this is only for looks and you're not actually going off road that's what I'd recommend, especially if you aren't lifting or anything else. You may be able to find gently used ones on fb marketplace as well. That was where I got my first set and then when they wore out I bought a new set recently.
    Icculus89[OP] and Manhattan like this.
  3. Jul 2, 2024 at 9:41 AM
    Icculus89
    Michael
    TN
    Yeah I don't intend to do any serious off-roading but like the look of A/Ts. Might just have to sell these ones and get some Toyo's.
    SlvrSlug likes this.
  4. Jul 2, 2024 at 9:43 AM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    68573939750__683045EB-1347-4B47-BCA8-1B6B595D1272.jpg Here’s Falken Wildpeak in oem size 265/70/17. They have been fantastic in wet and snow as they are also 3pmsf rated. Good enough to get you into your favorite hunting/fishing spot or a Bbq on the beach with the family. There’s lots of options out there. A lot of folks claim the Mickey Thompson are fantastic as well. I’ll probably give them a try next.
    Bagman and Icculus89[OP] like this.
  5. Jul 2, 2024 at 9:43 AM
    A tire with them more aggressive tread and sidewall will make a big difference cosmetically, even with stock wheels. Here's mine when I put stock size ko2s on it.
  6. Jul 2, 2024 at 9:44 AM
    Icculus89
    Michael
    TN
    Love that look, very clean! And these are the 265/70/R17?
  7. Jul 2, 2024 at 9:46 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Start here.
    I don't think you need to get new wheels to achieve what you want. I think you could safely go up to a 275/70/R17 without rubbing. Use this comparison tool, get a tape measure, go out and see what you can safely fit in there. Make sure you check measurements with full lock wheels turned both left and right. Use the center of the hub as your zero point.
    Icculus89[QUOTED][OP] likes this.
  8. Jul 2, 2024 at 9:47 AM
    I will leave this here for you to look at.
  9. Jul 2, 2024 at 9:53 AM
    wax poetic
    Lighting kinda sucked when I took that but that's Toyo Open Country AT3 in 265/70/17
    Icculus89[OP] likes this.
  10. Jul 2, 2024 at 9:55 AM
    HuskerRunner
    O,NE
    2023 SR5P
    I have no idea how many hours I've spent on this site looking at no lift rigs while debating tire choices. The below are just the MGM reference pics I've saved and I believe all are stock 265/70/17 ATs.
    Edit: Just noticed 3 of 4 I posted are Toyos. Guess which way I'm leaning...
  11. Jul 2, 2024 at 10:04 AM
    Run them down until you need tires. No need to be in a hurry to swap and you can't fit much larger on the stock wheels and stock height anyway. I just went stock size Toyo AT3 when the stock tires wore down. I'm on my second set now.
  12. Jul 2, 2024 at 10:24 AM
    Jedi5150
    Jedi5150 New Member
    2022 4Runner ORP
    I'm a mud terrain fan, so I usually buy KM3's or Toyo Open Country MT's, but for what the OP is asking for, I don't think there is a better tire made than the KO2. They last a long time, they look fantastic, they have great performance both on and off road, and they come in a huge variety of sizes.
  13. Jul 2, 2024 at 11:05 AM
    Yes
  14. Jul 2, 2024 at 11:35 AM
    BMerrill33
    BMerrill33 Someone once said ??? Something...
    Wyoming
    2020 T4R SR5P
    I went with Falken Wildpeak AT3's in stock 265/70/17 before a slight lift. Will go bigger when these are toast but so far a great tire and looks good. Have also seen Falken Rubiteks on stock height T4R and looked good if you are more of a road warrior than dirt and rock. Fairly aggressive look and good performance a well.
  15. Jul 2, 2024 at 11:41 AM
    Icculus89
    Michael
    TN
    Clean truck, I like it. What % tints do you have on your windows?
  16. Jul 2, 2024 at 11:42 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    That's what I have, but no lift. Here it is with the basket off. I'm not a big fan of filling up the holes. I don't want my wheel wells to bottom out before my suspension.
  17. Jul 2, 2024 at 11:44 AM
    Garlic
    Garlic New Member
    CO
    2024 TRD Off Road
    I’ve got stock size general grabber atx on mine and love them. Nice soft ride, kinda looks like a KO2 but cheaper and allegedly better on wet pavement.
  18. Jul 2, 2024 at 11:47 AM
    BMerrill33
    Wyoming
    2020 T4R SR5P
    Thanks! 25% on the front. Gets dark out here in Wyoming and I like to see out the windows! LOL. Rest are all stock tint.
  19. Jul 2, 2024 at 12:00 PM
    BMerrill33
    Wyoming
    2020 T4R SR5P
    Clean!
    backpacker[QUOTED] likes this.
