Timing belt replacement
Discussion in '5th Gen 4Runners (2010-2024)' started by Birddog6344, Jan 13, 2025 at 6:20 PM.
  1. Jan 13, 2025 at 6:20 PM
    Birddog6344
    Birddog6344 [OP] New Member
    Monday
    My 2017 4 Runner just turned 99K. The dealership wants at least 4K to replace it( not including a water pump if needed). Any advice/experience one way or another on replacing it or just let it be? I don't tow anything, don't go off roading ect. Drive it on trips, around town, and dirt/gravel roads while hunting. nothing extreme. Use 4 wheel drive in snow as needed, which isn't a huge amount. My personal trustworthy mechanic won't do it because its to involved. It runs great, no issues. I'm all ears!
  2. Jan 13, 2025 at 6:24 PM
    Stay away from that dealer and mechanic. Your 4Runner has a timing chain not a belt. No need to replace it.
  3. Jan 13, 2025 at 6:26 PM
    Saker New Member
    21 Black T4RORP
    I didn't know 2017 4Runners had timing belts..............
    New one on me :ohsnap:
  4. Jan 13, 2025 at 6:27 PM
    Technologic80
    Technologic80 Sexy Member
    Chris
    SE Michigan
    '23 TRD Off Road Premium
    Birddog,
    The 4.0L v6 engine in the 5th Generation 4Runner does not have a timing belt, it has an internal timing chain which normally never needs replacement.
    Did the dealership really say the Serpentine Belt needed replacement?
    Even so, if it is the Sepentine Belt, that runs between $7 & $20 depending on what brand you prefer on RockAuto.
    So yeah... like TF said, get away from that place. They are trying to shamelessly rip you off.
    ThatOneGuy likes this.
  5. Jan 13, 2025 at 6:27 PM
    kouack
    kouack New Member
    4Runner Limited 2024
    Bone stock
    Timing belt in a 2017? You mean timing chain
  6. Jan 13, 2025 at 6:28 PM
    TN_FunRunner
    TN_FunRunner New Member
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    Don't walk, run away! Never dark the doors of that place again.
    MEski4x4 and Rocko9999 like this.
  7. Jan 13, 2025 at 9:13 PM
    Texoma-Brad
    Texoma-Brad OK Yota
    Brad
    Texoma USA
    They should go to jail... Everyone above clarified that you don't even have a timing belt already. So... About the serpentine belt, that's your alternator, AC compressor, etc. It doesn't need replaced at 100k either. Not a chance - unless it's sat in the hot sun every single day and is frayed. You can look at it and see if it's frayed.
    Otherwise call us back at 200k. And don't set foot in that stealership again. They are dishonest.
  8. Jan 13, 2025 at 9:16 PM
    Are you getting a cold start rattle? Cam-crank correlation fault codes? No? Move on...
  9. Jan 14, 2025 at 8:34 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Why does your dealership want to replace your timing chain when it runs great, has no issues? You need to leave that place and never, ever return.
  10. Jan 14, 2025 at 8:42 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    You should change the serpentine belt at 100k, wear or no wear.
    Imdav2u likes this.
  11. Jan 14, 2025 at 8:53 AM
    But per the service manual its only inspect after 60,000miles on the specified intervals right?.
  12. Jan 14, 2025 at 8:55 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Correct. Inspect at 60k but change that out at 100k regardless. Cheap insurance.
    Imdav2u, Guppy1301 and kmeeg[QUOTED] like this.
  13. Jan 14, 2025 at 9:07 AM
    I just changed mine at 230,000 miles for the first time and it looked like i could have probably got another 100,000 out of it.
    Had a thermostat housing leak, looked at everything i needed to remove to fix it, decided to do
    1) water pump
    1) thermostat housing and gasket
    1) fan clutch
    1) A/C compressor
    1) serpentine belt
    1) belt tensioner
    1) all new Toyota Long Life coolant
    Figured if i was going to pull all the crap off the front of the engine, might as well replace some replaceable things before they go bad, after all it did have 230,000+ on all of them
    I say all that to say this, none of those items were giving me any troubles but i replaced them due to me being there, and having the money to do it now rather than let it nickel and dime me over the next 2-3 years as those things would likely finally start wearing out one by one.
    McSpazatron likes this.
  14. Jan 14, 2025 at 10:38 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    I don't know about you, but I inspect mine at every oil change (5K). It's so easy to do... I changed it out at 175K. It still had life left in it, so I keep it in my emergency repair kit as as a backup. Doubt I'll ever need it, but you know, "just in case".
    Turd Ferguson and kmeeg[QUOTED] like this.
  15. Jan 14, 2025 at 10:54 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Just like one can go about doing 15000 miles oil changes because the oil is Full Synthetic and it says on the bottle good for 20000 miles, it is prudent to do it every 5k to 10k.
    Similarly, I am not denying you cannot push the belt beyond 200k, but it is advisable to simply replace at 100,000.
    But that's just me, you do you.
  16. Jan 14, 2025 at 11:32 AM
    The 4Runner belt is really wide. It lasts a long time. This isn’t one of the crappy V-belts of the past that wore out quickly and would be heard squealing as the wore out.
  17. Jan 15, 2025 at 5:32 AM
    coachhomer
    coachhomer New Member
    Agree with this. And hold on to the old one. I changed one of ours at 70k but only because it was my daughters and she lives 600 miles from me. Good insurance policy and cheap and easy to do.
    catbrown357[QUOTED] likes this.
