Thermostat Help!
Discussion in '4th Gen 4Runners (2003-2009)' started by chiefrod1878, Apr 23, 2025 at 11:55 AM.
  1. Apr 23, 2025 at 11:55 AM
    chiefrod1878
    chiefrod1878 [OP] New Member
    Wednesday
    2005 4Runner Limited
    Hello, I was changing out the thermostat on my 2005 Limited, should have been an easy fix. However, I accidently broke one of the 3 bolts where the nuts go onto. I am looking to see if anyone has had this issue and what the best course of action would be.
  2. Apr 23, 2025 at 11:58 AM
    chiefrod1878
    Wednesday
    For reference I have a photo of what I am talking about. Fig 1 is the bolt that I broke and cannot put the nut back into. Does anyone know what the thermostat goes into or what Fig 2 is called?
  3. Apr 23, 2025 at 12:26 PM
    that should just be a stud, did you try just removing the stud?
  4. Apr 23, 2025 at 12:31 PM
    chiefrod1878
    Wednesday
    I didnt want to get ahead of myself by doing that, was thinking of possibly trying to weld the broken piece on. But also, I have no idea where to find a new stud, I have been looking online but havent found anything concrete about it.
  5. Apr 23, 2025 at 12:50 PM
    gkomo
    gkomo New Member
    San Diego, CA
    2014 Tacoma AC 4x4
    Is that the thermostat housing that has the broken stud in it?
  6. Apr 23, 2025 at 12:54 PM
    chiefrod1878
    Wednesday
    No, the stud is on the part i labeled Fig 2. I dont know what its called but I have found the whole part on rockauto for $90, but not seeing if the stud itself is replaceable. CH1066_Angle.jpg
  7. Apr 23, 2025 at 10:25 PM
    Gracio
    Gracio New Member
    Blayne
    Cloverdale, CA
    You can get replacement stud at most hardware stores. Looks like fairly easy access to drill and use easy out to remove stud.
    LOSTR4 likes this.
  8. Apr 24, 2025 at 3:13 AM
    Dan's 4runner
    Dan's 4runner New Member
    2010 pearl white 4Runner
    stock
    It looks like after removing the thermostat housing, there will be about 1/2" of old stud sticking out. That should be plenty enough to get a good vice grip on it. I'm not sure if heating the stud would be beneficial since it is anchored in aluminum.
    Gracio and LOSTR4 like this.
  9. Apr 24, 2025 at 9:35 AM
    It's usually called a water housing or coolant manifold.
    You can find replacement studs at McMaster-Carr, Fastenal, etc.
    You'll want to heat up the stud with a torch to break any loctite that may have been applied at the factory. While hot, try to unscrew the stud remnant with a proper stud socket.
  10. Apr 24, 2025 at 3:57 PM
    Buckaroo
    Buckaroo New Member
    2005 Ltd T4R 4WD V6
    I would hit it with some PB Blaster and get a very good grip on the stud stub with a larger pair of vice grips. When you are trying to get it turning, move it back and forth. Also, be careful not to mar the flange surface with the vice grips.
  11. Apr 25, 2025 at 6:51 AM
    always remember, you cant break something that is already broke. Always worth a try to get the stud out.
