The Car Care Nut on modern technology he loves and hates
Discussion in 'General 4Runner Talk' started by engineer90, May 18, 2024.
  1. May 18, 2024 at 2:54 PM
    engineer90
    engineer90 [OP] New Member
    NJ
  2. May 18, 2024 at 2:59 PM
    usfbulls
    usfbulls New Member
    Jay
    2023 Lexus GX460 Premium
    I haven't seen it but I hope the new Lexus camera/radar thing that monitors the driver's face made the cut (for worst.)
  3. May 18, 2024 at 3:01 PM
    Chozen
    Chozen New Member
    2024 4Runner ORP
    I’m a huge fan! If The Car Care Nut ever starts a cult I’m gonna sign up!
    Steely123 likes this.
  4. May 18, 2024 at 3:20 PM
    engineer90
    NJ
    He didn't touch on that, but he did mention the all-touch infotainments and electronic door handles
    usfbulls[QUOTED] likes this.
  5. May 18, 2024 at 3:25 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
  6. May 19, 2024 at 3:34 AM
    I agree with him on most of it. But especially the start /stop thing. It's annoying AF!
  7. May 19, 2024 at 4:35 AM
    Sin4R
    Sin4R New Member
    2024 Underground Limited
    Mall crawling kit.
    I also like blind spot monitor. Agree on start-stop, what a useless feature.
    2ndGen22re likes this.
  8. May 19, 2024 at 6:55 AM
    Noodles
    Noodles New Member
    I had it on my 2012 Mercedes-Benz and recently on my XC90 Volvo. Needless to say that while Mercedes system worked perfectly, 10 years later the Volvo still messed up my rear brake pads because they released the brake by 1-2 ms later than should have, causing premature rear brake pads wear.
    The auto start/stop is not a feature for the consumer. It’s a tool for the manufacturers to meet EURO 5/6/7 emission norms and to reduce CO2 emissions on paper. I always turned it off on every car.
  9. May 19, 2024 at 7:54 AM
    usfbulls
    usfbulls New Member
    Jay
    Actually, he did. It was #4 on his worst list - Driver Monitor System. The system will scan your face and send out warning beeps every time you turn your head away from looking straight forward. I guess we are no longer supposed to turn our heads to 1. look in the rear view mirror, 2. look at the passenger side mirror and 3. look at that huge laptop mandated by law that contains most radio and HVAC controls also called the infotainment screen.
