terrible tire shake after wheel rotation
Discussion in '5th Gen 4Runners (2010-2024)' started by Dohc97, Apr 3, 2022.
  1. Apr 3, 2022 at 6:01 AM
    Dohc97
    Dohc97 [OP] New Member
    My 2022 4runner with Method wheels have a very minor wheel vibration at 65 mph. It was so minor that I didn't even bother checking on it. Yesterday, I tool it to a dealer for it's 5k service which only was for tire rotation. Now, it has a terrible wheel vibration going past 55 mph. Where should I start looking?
  2. Apr 3, 2022 at 6:17 AM
    You need to get your tires balanced.
    Go to someone that can road force balance them......people have the best luck if they are balanced on a Hunter machine.
    Call around and see if any tire shops (or your dealer) has one.
    Singleminded, Toy4X4, 7385 and 4 others like this.
  3. Apr 3, 2022 at 6:46 AM
    karmatp
    karmatp New Member
    Trevor
    2016 SR5 4x4
    Are your wheels hubcentric? If not, one bolt tightened more than another will give you vibes. I learned my lesson years ago on a Tacoma and now only run hubcentric wheels on Toyota’s.
  4. Apr 3, 2022 at 6:49 AM
    Yoytota
    Yoytota New Member
    FL
    SR5 4X4
    What size wheels and tires? Is the vibration in the steering wheel or does it feel like it's coming from the back end now? One option is to use the spare tire to try to isolate the will and tire with the problem, then mark it and make sure they fix it right
  5. Apr 3, 2022 at 6:49 AM
    Tmiesowicz
    Tmiesowicz New Member
    The better half of New York
    I don’t understand how if all tires are ‘properly balanced’ and in Spec that people have issues after a simple tire rotation. I never experienced that on any vehicle ever and literally am dreading my first tire rotation after the stuff I see here as I already fought the fight of the steering wheel shimmy @ 2 miles
  6. Apr 3, 2022 at 6:51 AM
    Who put the Method wheels on your 4R?
  7. Apr 3, 2022 at 6:51 AM
    Yoytota
    Yoytota New Member
    FL
    SR5 4X4
    The forerunners front end design and geometry make it very susceptible to very minor imperfections in the wills, tires and road. This thing's made to hold up in war zones and crawling over rocks not riding like a Cadillac at highway speeds I don't think I've ever been in one that didn't vibrate or shake some on the highway
    LuLu and nimby like this.
  8. Apr 3, 2022 at 6:54 AM
    Dohc97
    My Method wheels are hub centric.
    I am thinking is that the lug nuts were over torqued using an impact gun. Can I just loosen the lugs and re torqued the nuts while the vehicle is on the ground? Or do I need to raise it off the ground?
    Yoytota likes this.
  9. Apr 3, 2022 at 6:55 AM
    Dohc97
    I took it to a neighborhood gas station.
  10. Apr 3, 2022 at 6:57 AM
    Yoytota
    Yoytota New Member
    FL
    SR5 4X4
    I do 60 ft lb off the ground then 78 on the ground get it up the highway speed and then re-torque it on the ground to 80 but adjusting torque rarely fixes anything like this
    Toy4X4 likes this.
  11. Apr 3, 2022 at 6:58 AM
    Dohc97
    I bought the wheels and tires from Tire Rack. It was fine until the tire rotation yesterday.
  12. Apr 3, 2022 at 6:59 AM
    Dohc97
    Wheels are 17x8.5; tires are 265x70x17. Vibration is on the steering wheel.
  13. Apr 3, 2022 at 6:59 AM
    That being the case, you need to find a tire installation place with a Hunter road force machine as @nimby suggested.
    Singleminded, Toy4X4, nimby and 2 others like this.
  14. Apr 3, 2022 at 7:02 AM
    Yoytota
    Yoytota New Member
    FL
    SR5 4X4
    You'll notice tire and wheel imperfections and imbalance much more when you put them on the front then in the rear had start with just getting the front tires balanced if you don't want to try to isolate the issue with the spare
    Singleminded and nimby like this.
  15. Apr 3, 2022 at 7:02 AM
    Dohc97
    The wheels and tires were delivered from Tire Rack balanced. I only took it to a gas station for them to swap the oem wheels with the Method wheels.
  16. Apr 3, 2022 at 7:05 AM
    Dohc97
    I can't put the spare in there as I have a TRD Sport. The spare is the oem 20 inch wheel/tire just like the Limited.
  17. Apr 3, 2022 at 7:05 AM
    BionicRandy
    BionicRandy New Member
    Randy
    TX Hill Country
    Lots of goodies
    You can do it on the ground. Just don’t loosen all 6 at the same time. I have had a whole bunch of Toyotas, never heard about the finicky lug nut torque thing. Wow crazy. Find a Discount Tire and go there from now on. You can go back as often as you need to get it riding right.
    rangers1976 likes this.
  18. Apr 3, 2022 at 7:06 AM
    So Tire Rack says. Unless you get them done locally, you'll have to live with the vibraton. Let TR know of the issue. They'll probably recommend or find a shop nearby you can use.
    nimby, 7385 and 2Toys like this.
  19. Apr 3, 2022 at 7:07 AM
    Yoytota
    Yoytota New Member
    FL
    SR5 4X4
    Yes road Force balance anytime you're having issues with vibration if it doesn't work on a regular computer. Balancer you'll be taking it to a road force machine afterwards anyway
    nimby likes this.
  20. Apr 3, 2022 at 7:09 AM
    Yoytota
    Yoytota New Member
    FL
    SR5 4X4
    I just get the front tires road force balance then if you don't want to play around with moving back, tires to the front one by one to try to isolate it so you only have to pay to balance one tire
  21. Apr 3, 2022 at 7:18 AM
    DallasTRDPro
    DallasTRDPro New Member
    Dallas
    2021 Honda CRV...UGH!
    I had a shake and finally on my 5th time each at a different Discount Tire they finally road force balanced them. That finally fixed the issue. I was about to force them to replace the tires.
  22. Apr 3, 2022 at 10:33 AM
    Yoytota
    Yoytota New Member
    FL
    SR5 4X4
    Did they make you pay extra for the RF balance?
  23. Apr 3, 2022 at 10:37 AM
    Yoytota
    Yoytota New Member
    FL
    SR5 4X4
    May have been gomer pile in there working on it
  24. Apr 3, 2022 at 10:42 AM
    Discount tire shop near me was really good on road force balance. I had the issue on my brand new 2021 TRD Pro.
    Can't believe how poor quality it had from Toyota especially with the higher price tag..:facepalm: I had to do alignment as well. My other 4Runners that came directly from factory in Japan was in far better quality.
    Toy4X4 likes this.
  25. Apr 3, 2022 at 11:08 AM
    Tmiesowicz
    Was the alignment out of spec?
  26. Apr 3, 2022 at 11:16 AM
    ridetime
    ridetime New Member
    2022 Limited 4x4 Blizzard Pearl
    Really? My 22 is glass smooth at any speed. Come to think of it, so was my 17. What exactly is it about the "front end design and geometry" that is a problem?
    Tmiesowicz likes this.
  27. Apr 3, 2022 at 11:19 AM
    Tmiesowicz
    My solid front axle grand Cherokee’s had a smoother ride, and that’s with 100,000 miles + on them. Something just doesn’t seem right.
  28. Apr 3, 2022 at 11:39 AM
    Yoytota
    Yoytota New Member
    FL
    SR5 4X4
    My straight axle Cummins road smooth because of the weight in the front from the 67 but my straight axle hemi 64 road like crap in the front. Felt like the tires would come off the road on the highway when you had small bumps lol
    Tmiesowicz[QUOTED] likes this.
  29. Apr 3, 2022 at 11:41 AM
    Yoytota
    Yoytota New Member
    FL
    SR5 4X4
    I'm not sure but when I looked at it there were small thin parts going all over the place. It looked incredibly complicated
  30. Apr 3, 2022 at 12:01 PM
    As seen on alignment machine screen lot of reds. The shop invited me in to show bad alignment spec and said "are you sure you want to pay for alignment? since this is brand new you can take it back to Toyota to fix.". I opt to pay out of pocket and get it fixed right.
    O9Nm4xYVA2wx6fKy2PY3zU-Nt1Sk2w8YhMaLIB-m_2f7632c27441d9507353ca2e072c14b53e930056.jpg
    Yoytota likes this.
