Tail lights / Running lights not working but brake lights do work
Discussion in '4th Gen 4Runners (2003-2009)' started by mrshanno, May 21, 2023.
  1. May 21, 2023 at 1:28 PM
    mrshanno
    mrshanno [OP] New Member
    Hi,
    Could anyone help diagnose my lights issue?
    1- Brake lights work
    2- Tail lights do not work even when headlights are on (dangerous at night)
    3- headlights work (see pic)
    4- Side running lights work in front, but not when headlights are on (see pic)
    5- License plate lights do not work (but I haven't checked bulbs yet)
    6- Reverse lights work
    7- Turn signals work
    So the main problem is the tail lights and running lights. I tried to change the bulb in the tail light (#7443) but it turned out to be an LED assembly (see pic)
    It does not appear that the 10A fuse under the steering wheel (position #43) or the 10A fuse under the hood (position #3) are burnt.
    Any ideas?
    Thanks!
  2. May 22, 2023 at 6:41 AM
    mrshanno
    Just a quick follow up...I removed the wiring harness from the tail light assembly and put a 7443 light bulb into the wiring from the front of the vehicle. The brakes lit the bulb up, but the bulb did not light up when the headlights were on, so maybe a fuse or relay? I'm going to replace fuse even though it does not look burnt up. Any other ideas?
    Thanks
  3. May 28, 2023 at 10:54 AM
    mrshanno
    It was the tail light relay which is hidden on the back of the interior fuse block assembly. The lower dash area had to be taken apart and the fuse box dropped in order to access it.
    steelevo and xtremewlr like this.
  4. May 28, 2023 at 12:05 PM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    Thanks for following up with the answer to the issue. I try to help most people here when I can but I have no experience with the issue you had so couldn't help. Glad you were able to get it figured out.
  5. Mar 9, 2024 at 4:12 PM
    MeganThompson
    MeganThompson New Member
    Megan
    2017 toyota 4 runner
    I cam across this forum, and am having the same issue as explained!
    After reading I purchased a new relay, but after disassembling my dash and accessing the box, I do not see the relay at all. Where is it located on the fuse box???
  6. Mar 17, 2024 at 11:39 AM
    CB20054runner
    CB20054runner New Member
    2005 Toyota 4 Runner 4.7L V8 4WD Limited
    I am experiencing the same problem. Headlights work, turn signals work, brake lights work but running lights (tail lights) do not work when the headlights are turned on. I have replaced the associated fuses & relay, checked all the bulbs, replaced the rear tail lights, replaced the turn signal switch and the running lights still do not work. Does anyone have any suggestions? What am I missing?
    Sincerely appreciate any assistance you can provide.
  7. Mar 17, 2024 at 11:43 AM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    The OP said that the relay was hidden on the back side (firewall side) of the fuse box. Hope this helps.
    CB20054runner likes this.
  8. Mar 17, 2024 at 11:48 AM
    CB20054runner
    Yes, I saw that in the OP, replaced the associated relay and the problem is still persisting.
