Tacoma brake upgrade 2000 4runner
Discussion in '3rd Gen 4Runners (1996-2002)' started by Al 2000 4runner, Jan 26, 2021.
  1. Jan 26, 2021 at 1:38 PM
    Al 2000 4runner
    Al 2000 4runner [OP] New Member
    Al
    Pacifica ca
    20004runner
    Lift kit
    Hello everyone My question is will stock four runner wheels fit over the new Tacoma calipers and rotors on a break upgrade?
  2. Jan 27, 2021 at 10:46 AM
    treyus30
    treyus30 New Member
    Trey
    '99 Limited & '99 Tacoma PreRunner
    Pretty sure Tacomas have the same calipers and rotors. Tundra is the brake upgrade. For those you need at least 16" wheels; larger is recommended.
  3. Jan 28, 2021 at 12:53 PM
    Al 2000 4runner
    Al
    Pacifica ca
    20004runner
    Lift kit
  4. Jan 28, 2021 at 8:40 PM
    RoxToy00
    RoxToy00 New Member
    rocky
    3rd owner of 2000 2whldr 4runner
    none
    And seems to be 2 different Tundra calipers, WE and WS (not sure of latter) mold identifiers in caliper. To use WS calipers, dust shield trimming appears to be necessary, which WE calipers apparently don't require. Planning this upgrade with WEs and Tundra LBJs at same time, will update when done.
  5. Jan 28, 2021 at 8:52 PM
    I believe the WE’s are the 199mm and the WS are 213mm, and i also think that there is only one oem 16” wheel that will not clear with the 213’s.
    treyus30 likes this.
  6. Jan 28, 2021 at 9:14 PM
    RoxToy00
    RoxToy00 New Member
    rocky
    none
    Yes, believe you are right. Would 199 and 213 be a measurement in mm (length?), or tied to some obscure code system?
  7. Jan 29, 2021 at 8:26 AM
    Yes millimeters.
  8. Feb 22, 2021 at 1:30 PM
    senior master
    senior master New Member
    2002 toyota 4 runner limited 4x4
    stock
    on a 2002 toyota 4 runner 4x4 with 16 inch stock aluminum 5 spoke wheels when performing the TUNDRA BRAKE UP GRADE witch calipers and rotors fit with the stock 16 inch wheels and what year TUNDRA parts do I BUY?
  9. Feb 23, 2021 at 9:47 AM
    RoxToy00
    RoxToy00 New Member
    rocky
    none
    WE casting for 199mm calipers off 2000 Tundra will not require trimming of dust shields. WS casting 213mm calipers will require said trimming. Obviously both will need Tundra rotors.
  10. Feb 23, 2021 at 9:48 AM
    RoxToy00
    RoxToy00 New Member
    rocky
    none
    I would do the Tundra LBJs at same time.
  11. Feb 28, 2021 at 10:07 PM
    Husky Driver
    Husky Driver Kyna's chauffeur
    Kipp
    40°35'09.0"N 105°04'38.3"W
    2k T4R3 SR5 Highlander Sport TRD
    Toytec Ultimate 3" lift susp w/ OME 891 rear coils, Bilstein 5100 shocks front & 5125 rear, ARB 'Roo Bar, Warn VR10k, 0.7, 2 & 11-meter 2 way radios FCC Lic KE0TDD, Nitrogen inflated 33" BFGoodrich All-Terrain T/A KO2s, FlexFuel E-85 conversion, AFe lifetime filter, Savage Offroad rock sliders, Ryno All Terrain 4.5mm skid plates, Line-X coatings on the armor, LifetimeLED & Rigid Industries LED headlights, UltraGauge 1.2, T3q 4.10 eLocker with armor from LROR, AmsOil lubricants used throughout. CBI plate rear bumper with swingaway, SPC Light Racing UCAs, ARB SS170HF Safari snorkel w/ Afrikaans centrifugal pre-cleaner, Tacoma antenna mod, TRD Supercharger w/ URD 7th inj. & URD pulleys, Anti-Dark engine bay lighting system. Having gone 250k, Aug 2016 was the time to replace the original clutch & get the driver's seat rebuilt/stuffed. Front & back Weathertech liners. '05 Tundra front disc brake swap. Full length Rocky Mountain Rack with 40" lightbar, Alternating strobe rear dust lights. I used a warm weekend in March 2022 to finally install my brand new from old stock 2000 4Runner driver's seat. $800 directly from the factory in Sapporo, Hokkaido, Japan.
    I've done this mod. 2005 WE 199mm Tundra rotors & calipers only. The Tundy calipers require at least a 16" rim b/c the clearance is about 1/8" to 1/4". The fun part is I bought new parts from Napa for $380 which is about 2/3 the price for Toyota OEM. The Tundra LBJs don't fit 4R, neither do the Taco's. Toyota corp says that LBJs need to be replaced every 100k BUT they are over engineered to last up to 200k. I bought my replacement LBJs from Amazon for about $100/each. Wear limit is 1/32" of play.
    You'll love the Tundy brakes, I can stop on a dime & give change.
  12. May 17, 2021 at 5:20 PM
    DaveR
    DaveR New Member
    Dave
    1999 Limited
    Slight lift, off road shocks and struts
    Husky, when you did your Tundra upgrade, did the brake lines reconnect to the new calipers without modification? How did that go?
  13. May 17, 2021 at 7:06 PM
    senior master
    stock
    Everything work out great I used all new toyota parts and I do recommend new metal brake lines one broke when I loosen the brake line the both of them were only 20 dollars and I used steel braided brake hoses for the front I have them for the rear just haven't installed them yet and you may won't to use a brake bleeder so you don't wipe out the master cylinder when bleeding the brakes and if you look on the web there is a listing that shows what wheels fit what calipers I did the big calipers I have 16inch wheels flower wheels I think that's what they called them my next upgrade is a super charger with a 7th injector system
  14. May 19, 2021 at 6:59 PM
    shake007
    shake007 New Member
    97’ Supercharged SR5
